ᐅ Why do some Billy bookshelf boards warp under load?
Created on: 7 Mar 2015 18:27
APEXJAN
Hello everyone, I have a question that has been on my mind for a while: why do some Billy-style shelves warp under load?
I have noticed that especially with heavier items, the shelves tend to sag or deform over time. I suspect it has to do with the material properties and the construction of the shelves, but I am not sure which factors exactly are involved.
I am particularly interested in whether this is a general weakness of this type of furniture, or if it is more related to improper load distribution, moisture, or incorrect installation. Perhaps the materials used or the thickness of the shelves also play a role?
I would appreciate your opinions and experiences!
asete
9 Mar 2015 18:52
As an addition, I would like to explain the material properties and long-term effects in more detail:
The standard Billy shelves are made of particleboard coated with melamine resin. The particleboard itself is a composite material composed of pressed wood particles and binders. Due to its structure, it has considerably less elasticity and load-bearing capacity than solid wood.
The melamine coating does reduce moisture penetration but is not completely waterproof. This means that with increased indoor humidity or occasional dampening, the shelves may swell slightly. Combined with load stress, this can intensify warping.
I also recommend taking temperature and humidity fluctuations in the room into account, as wood-based materials can react to these over time.
Technically, the bending can also be calculated using the modulus of elasticity (E-value). For particleboard, this is typically about 2,500 to 3,500 N/mm², compared to solid woods like beech (E approx. 10,000 N/mm²).
Another weak point is the type of load: the shelves are primarily designed for vertical loads. Point loads or lateral forces can put additional stress on the material.
My recommendations:
- Ensure an even distribution of weight.
- Use additional supports in the middle of the shelf if possible.
- Avoid exposure to moisture.
- For higher loads, consider replacing with sturdier shelves.
In conclusion: Warping does not happen overnight but is the result of material limitations, type of load, environmental influences, and construction.
jakob70
10 Mar 2015 08:19
APEXJAN schrieb:
Why do some Billy shelf boards warp under load?
Because the shelves are made of thin particleboard, which bends when overloaded. There isn’t much more to explain.
asete schrieb:
Consider replacing them with stronger shelves if you expect higher loads.
Exactly, if you want it to be truly stable, it’s better to buy different shelf boards.
