ᐅ Why do some Billy bookshelf boards warp under load?
Created on: 7 Mar 2015 18:27
APEXJAN
APEXJAN
7 Mar 2015 18:27
Hello everyone, I have a question that has been on my mind for a while: why do some Billy-style shelves warp under load?
I have noticed that especially with heavier items, the shelves tend to sag or deform over time. I suspect it has to do with the material properties and the construction of the shelves, but I am not sure which factors exactly are involved.
I am particularly interested in whether this is a general weakness of this type of furniture, or if it is more related to improper load distribution, moisture, or incorrect installation. Perhaps the materials used or the thickness of the shelves also play a role?
I would appreciate your opinions and experiences!
parpeo
7 Mar 2015 18:49
Hello APEXJAN,
Your question is very well formulated and points in the right direction. In fact, the Billy shelves often warp under load due to several interacting reasons.
First: the material. Billy shelves are usually made from particleboard panels with a melamine coating. Particleboard is cost-effective but has lower load-bearing capacity and can swell when exposed to moisture.
Second: the thickness of the shelves. The standard thickness is about 1.8 cm (0.7 inches), which is not ideal for heavy loads.
Third: the support points. The shelves typically rest only on small metal pins, which concentrates pressure on small areas and promotes bending.
And fourth: load distribution. Heavy and unevenly distributed loads naturally worsen the problem.
In summary: it is a combination of material, design, and load that causes the warping. A few tips: distribute loads more evenly, add additional supports to the shelves, or use replacement shelves made from thicker materials.
flota
8 Mar 2015 09:31
This is an important point raised by parpeo.
parpeo schrieb:
The shelves are usually supported only by small metal pins, which concentrates the load on a small area and promotes bending.
This means that the shelf itself is designed not to carry very heavy individual weights on one shelf. For example, bookcases should be loaded with books evenly distributed to avoid local overloading.
Another factor is the shelf span: the wider the shelf, the higher the risk of bending. Billy shelves are about 80cm (31.5 inches) wide, which is quite a length without support for such thin material. Additional supports in the middle help a lot here.
So, when storing heavy items, it is recommended either to distribute the load across several shelves or at least to plan for the installation of supports or reinforcements.
chenlen
8 Mar 2015 18:05
For a clear explanation, the material and structural aspects can be summarized as follows:
First, the load-bearing capacity of particle boards is limited, especially under tensile and bending stress. The spacing between the support points (metal pins) of around 80 cm (31.5 inches) is borderline for the material thickness of approximately 18 mm (0.7 inches).
A greater thickness or reinforced materials (e.g., solid wood, MDF of appropriate thickness) can significantly reduce deflection. The type of load (point load vs. distributed load) also influences the bending stress.
There is a formula to calculate the maximum deflection of a beam under load:
w = (5 * q * l^4) / (384 * E * I)
where w is the deflection, q is the uniformly distributed load, l is the length, E is the modulus of elasticity of the material, and I is the moment of inertia.
The thin shelves have a low modulus of elasticity and small moment of inertia, which promotes deformation.
Conclusion: For loaded shelves, it is advisable to either improve load-bearing capacity through reinforcement measures or reduce the load.
Morgan
8 Mar 2015 20:15
I completely understand the issue, as I experienced the same problem with my Billy shelf. 🙂
chenlen schrieb:
The type of load (point load vs. distributed load) also affects the bending stress.
This was the deciding factor for me. I stored heavy binders evenly, but on two shelves, I concentrated a lot of weight in one spot. As a result, the shelf bowed exactly at those points.
What helped me was simply adding wooden slats as additional support in the middle. This significantly reduced the load and prevented further sagging.
It’s also reassuring to know that this isn’t a defect or material failure, but a physical issue that can be solved with simple measures. 🙂
Z
zartra
9 Mar 2015 07:42
Simple tip: If the floors sag, distribute the load or add additional supports in the middle of the shelving unit.
Particle boards cannot support much weight when they are that thin.
