ᐅ Why do hollow core doors squeak, and how can I prevent it?
Created on: 5 May 2015 20:37
Ronapin
Ronapin
5 May 2015 20:37
Recently, I have noticed that the doors of my IKEA Billy bookshelf squeak constantly when opening and closing. Since I don’t want to remove or completely rebuild the shelf, I’m interested in knowing where this squeaking typically comes from and how I can prevent it permanently.
Could it be related to the material, the type of hinges, or the installation? Are there specific lubricants or simple tricks that might help? I have heard about silicone spray or graphite here and there, but I’m unsure if these could be problematic on plastic parts or if they might affect the appearance.
I look forward to tips, especially practical and easy-to-apply suggestions on how to get rid of the annoying noise without damaging the shelf or having to replace any parts.
emmaju
5 May 2015 21:12
Squeaking in Billy-style doors usually comes from the hinges or slight friction between moving and fixed parts, often because the joints have hardened due to dust, dirt, or insufficient lubrication. IKEA often uses metal hinges with plastic washers on these shelves, which can cause noise when dry.
A proven first step is to treat the hinge with an appropriate lubricant. Silicone spray is actually recommended because it doesn’t stick, doesn’t harden, and works well on both plastic and metal parts. I would suggest opening the shelf slightly beforehand and applying the spray directly onto the hinge pins. Then open and close the door several times so the lubricant spreads evenly.
If silicone spray is not available, dry graphite powder can also work, although it might be a bit messier. Oil, such as sewing machine oil or WD-40 oil, is less suitable because it often attracts dirt and becomes sticky over time.
Important: When applying lubricant, be careful not to get it on visible wood surfaces or painted areas, as it can leave stains.
In summary: The squeaking is usually caused by a lack of lubrication and material friction. The best prevention is targeted re-lubrication with a dry lubricant like silicone spray.
reybo
6 May 2015 09:43
I would like to go into more detail on the topic and add some points that might help, especially if the lubrication alone does not achieve the desired result.
First, it is important to know that Billy cabinet doors from IKEA are usually mounted with a simple hinge, which is sturdy but made from inexpensive standard materials. The hinges often contain small plastic bushings or bearings that are meant to facilitate movement, but over time they can harden or become dirty. This causes the squeaking.
It is also essential to check the condition of the shelf’s placement: if the shelf tilts slightly or is not completely level, slight deformation can exert door forces on the hinge, increasing friction and promoting squeaking. Therefore, check for levelness and, if necessary, adjust the shelf with shims or small wedges.
If you want to completely remove the hinge, you can carefully unscrew it and clean it in warm water with some dish soap — often fine dust and dirt collects in the moving parts, which can be removed this way. After that, apply a thin layer of silicone spray to the moving parts before reassembling.
Another potential issue can be the door surface: if the door rubs against areas that may be slightly warped, this can also cause squeaking. Sometimes, a slight adjustment of the door position by tightening or loosening the screws on the hinges can help.
One more tip: sometimes, instead of silicone spray, a special polymer grease or a PTFE-based lubricant works better. These products are more durable and penetrate well into plastic and metal connections.
One last question: has your shelving unit been assembled for a longer time, or did you recently put it together? Some problems only occur after longer use or when the wood warps slightly.
SINTAR
7 May 2015 07:55
reybo schrieb:
Check the levelness and, if necessary, level the shelf using washers or small wedges.
This is often the simplest and most important step. If the doors hang unevenly, they tend to squeak quickly.
emmaju schrieb:
Silicone spray is actually recommended for this.
Applying silicone spray or graphite powder to the hinges usually helps. Avoid using oils, as they attract dust.
