ᐅ Why do BILLY doors sometimes stick?
Created on: 13 Jun 2024 08:37
sarklo
sarklo
13 Jun 2024 08:37
Why do BILLY cabinet doors sometimes stick?
Over the past few weeks, I’ve noticed that the doors on my BILLY bookshelf occasionally stick, meaning they don’t open or close as smoothly as they did at first. The problem seems worse on days with high humidity. I’m curious about the exact reasons for this. Is it due to the material properties, warping of the doors, or could mechanical issues like improperly adjusted hinges be causing it?
I’ve heard various explanations, from wood swelling to poor assembly and internal material stresses. It would be great if someone with experience or technical knowledge could provide a detailed explanation of why BILLY doors sometimes stick, and especially how to prevent or fix this issue permanently. Tips on optimal adjustment or maintenance are also welcome!
Josefane
13 Jun 2024 10:42
Interesting question.
First of all, we should clearly identify the main causes of potential door issues in furniture made from particleboard, such as BILLY: 1) material swelling due to moisture, 2) warping caused by temperature and humidity fluctuations, 3) screws that loosen or hinges that are improperly installed, 4) manufacturing precision.
sarklo schrieb:
Especially on days with high humidity, the problem seems worse.
This is exactly the key point. Particleboard is sensitive to moisture, which can cause slight expansion. This often explains the sticking.
However, I wonder whether the issue with BILLY is truly due to the hinges or simply the choice of material, which is not ideal for humid environments. Does anyone know of reliable sources confirming that IKEA deliberately uses material with high moisture sensitivity in BILLY? That would be a serious flaw.
It would be good to verify these claims before quickly blaming the material. Perhaps the installers are simply not thorough enough when adjusting the doors.
RENMA
13 Jun 2024 14:06
For clarification:
The construction of BILLY shelves uses particleboard with a melamine resin coating. The doors often contain a thinner fiberboard or particleboard with a foil covering, which affects their response to moisture.
Door sticking is usually caused by slight variations in the material. In high humidity, the fiberboards swell, causing minor dimensional changes. The hinges, which on BILLY shelves are not adjustable, then cannot align properly, resulting in sticking.
Additionally, the thin doors on BILLY sometimes warp slightly.
To clarify: readjusting the hinges with a Phillips screwdriver can usually resolve the sticking issue.
It is important to know that the material itself is only partially suitable for damp environments, so moisture sources should be kept away to minimize deformation.
These facts are supported by numerous user reports and IKEA material data sheets.
If the sticking persists, I recommend at least temporarily removing the doors to allow them to dry.
dijan
14 Jun 2024 09:29
I’m very familiar with those BILLY doors as well :-)
Josefane schrieb:
Particleboard panels are sensitive to moisture
That’s really the key point. As soon as the doors get damp from rain through an open window, they start creaking louder than birds in the morning :-)
What helps? I regularly adjust the doors, especially in spring and autumn when the humidity fluctuates. A small turn of the hinge screws and everything relaxes again. I also admit that sometimes I allow the shelf to bear slight “balancing” forces so that the wood doesn’t resist too much.
Also: avoid hanging heavy loads on the doors 😄
Sometimes lubricating the hinges well helps as well. No high-tech stuff needed—just a little WD-40 or some other light lubricant makes everything run even smoother.
RENMA
15 Jun 2024 07:58
dijan schrieb:
I regularly readjust the doors, especially in spring and autumn
That is generally a very sensible approach. Regular readjustment is a form of maintenance that is recommended for particleboard or MDF furniture.
Additionally, a technical note: The hinges on BILLY units are so-called Euro hinges with built-in height, side, and depth adjustment. This allows you to fix the issue without removing the doors.
For those unfamiliar with these adjustment options, I recommend checking the IKEA online manual or watching YouTube tutorials on adjusting these hinges. This way, you can quickly and permanently prevent doors from sticking.
