ᐅ What types of casters or wheels can I use to make Ikea Besta furniture mobile?
Created on: 11 Nov 2023 18:07
Risuso
Risuso
11 Nov 2023 18:07
Good evening everyone, I am planning to make my Ikea Besta furniture more mobile by adding casters. My question is: which types of casters can I use to make Ikea Besta furniture stable and secure when moved? It is important to me that the casters have sufficient load capacity and do not negatively affect the appearance too much. I have seen different types, such as swivel casters with or without brakes, furniture gliders with wheels, and so-called floor-protecting casters. Does anyone have experience with which casters work best, and maybe some tips on installation? I want to avoid the furniture becoming wobbly or unstable afterwards. Thanks in advance for your support!
SUBEN60
11 Nov 2023 20:29
The selection of suitable casters for Ikea Besta furniture should primarily be based on the following criteria:
- Load capacity: The casters must be able to safely support the weight of the fully assembled furniture. Consider the total weight including contents.
- Attachment method: Ikea Besta furniture has different base constructions. Casters with screw mounts or plate attachments are often the most suitable.
- Brake: For stability, a caster with a locking brake is recommended, especially on smooth floors.
- Floor protection: Soft PU casters or those with rubber tread help prevent scratches on parquet or laminate flooring.
For the Besta furniture type, casters with a diameter of 50–65 mm (2–2.5 inches) are often suitable. It is important to ensure an even installation of all casters to avoid wobbling.
Depending on the model, mounting plates may be required for installation, as the original underside does not always provide attachment points for casters. Stability can be enhanced by additional screws on sturdy frame parts.
If appearance matters, discreet black-gray casters are advisable; heavy metal casters often look out of place. Casters with cover caps or integrated shields can help here.
In conclusion, I recommend choosing casters designed for medium load capacity furniture, avoiding casters that are too small to ensure mobility even on uneven surfaces.
Domau0
12 Nov 2023 09:11
Hello Risuso, to give you a more detailed answer to your question:
Basically, there are three main types of casters to consider for Ikea Besta furniture:
- Swivel casters, which rotate freely and are ideal if the furniture will be moved frequently. These usually come in different diameters ranging from 50 to 75 mm (2 to 3 inches) and often have an integrated brake for added safety.
- Lockable casters, which offer less maneuverability but have the advantage of being fully locked when needed. I recommend this option especially for furniture that sometimes remains stationary.
- Furniture feet with integrated casters or so-called combination elements with both wheels and feet, which are visually more discreet and provide good stability.
When purchasing, pay attention to the maximum load capacity of the casters. Ikea Besta shelves can quickly weigh 50 kg (110 lbs) or more depending on their contents. To be on the safe side, you should choose casters that can support at least 1.5 times the expected total weight.
There are several options for mounting: directly on the carcass by screwing, although this is not always practical. Alternatively, you can attach narrow wooden strips underneath the furniture and screw the casters onto those. Another option is special adapter plates that are available for casters. These provide better stability and are usually easier to install.
Finally, one tip: consider the type of flooring. Rubberized casters are suitable for hard floors to avoid scratches. For carpeted floors, harder plastic casters work better.
Do you already have an idea of how you will use the furniture? Will it be moved frequently or only occasionally?
I hope this helps you for now!
KLO-KA
13 Nov 2023 14:38
Risuso schrieb:
What types of casters can I use to make Ikea Besta furniture stable and secure while mobile?
Simply use swivel casters with a locking brake. A diameter of 50 mm (2 inches) is usually sufficient for Besta. Screw them under a sturdy beam, so nothing wobbles.
lajudo
14 Nov 2023 07:25
KLO-KA schrieb:
Just use swivel casters with a locking brake.
Additionally: Consider rubber-coated wheels if you have parquet or laminate flooring. They are quieter and protect the floor.
