ᐅ What tips are helpful for assembling IKEA PLATSA units in rooms with sloped ceilings?
Created on: 26 Oct 2017 17:34
trajon43Hello everyone,
I am currently planning to install an IKEA Platsa shelving system in a room with sloped ceilings. Since the slope usually means the available storage space needs to be custom-fitted and the installation is made more difficult by the angled surfaces, I wanted to ask the community: What tried-and-true tips or techniques do you use when assembling and precisely fitting Platsa units in rooms with sloped ceilings?
Specifically, I am interested in advice on how to accurately measure under the slope, ensuring stable installation despite uneven walls, and tools or aids that help to assemble and align the modules as smoothly as possible.
Does anyone have experience adapting the back panels, using brackets, or incorporating custom cuttings? I look forward to your detailed and practical suggestions!
The most important thing is to measure the roof slope precisely, including the angles of inclination. Then you can secure PLATSA elements at the corners using angle profiles to ensure they stand stably. If necessary, shorten the back panels so they do not press against the slope.
I am happy to provide a detailed guide that can help you:
- Take precise measurements: Use a spirit level and protractor to determine the pitch angle of the sloped roof and record all necessary lengths very accurately. It is best to use a tape measure that can also measure diagonally.
- Prepare the parts: To adjust the back panels, it is advisable to carefully cut them along the measured lines using a fine-toothed saw or a utility knife—accurate markings before cutting are essential.
- Assemble the components: When screwing the modules together, clamp them first to prevent slipping. To secure them on the slope, you can use sturdy metal brackets fixed to the wall.
- Wall anchoring: Although not always mandatory, attaching the modules to the wall is recommended, especially for sloped ceilings with limited space.
- Avoid mistakes: Do not remove the back panels entirely, as they provide stability; only shorten them where they actually come into contact with the slope.
Summary: Accurate measuring, careful adjustment of the back panels, secure clamping, and wall anchoring are crucial for a clean result under sloped ceilings.
I can only say: Go for the assembly! 😊 The PLATSA is very flexible, and if you spend a bit of time preparing, everything will go very smoothly.
I also found that important! I specifically adjusted the back panels to fit the slope, which made a big difference in both stability and appearance.
And if you need help holding parts in place, get someone to assist you—you’re not alone, and that makes a lot easier! 💪
Always remember: A challenge is an opportunity to improve your DIY skills!
Nikoan63 schrieb:
Shorten the back panels if necessary so they don’t press against the slope.
Patricknon28 Oct 2017 08:21As an additional note, I want to emphasize the importance of measuring angles: roof slopes are rarely perfectly symmetrical, so a standard tape measure is usually not sufficient.
I recommend using a digital angle finder or a combination of a spirit level with adjustable angle settings to accurately match the exact slope. This is the only way to ensure a precise fit for the side and rear walls.
Additionally, it is advisable to temporarily support the components with battens or strips during assembly before final screwing. This prevents tilting and makes adjustments easier.
For cut pieces, MDF or plywood works well if you need to bridge small gaps that can be visually concealed with trimmed panels.
Construction under sloped ceilings requires precise work; otherwise, stability will suffer. For safety reasons, attaching to the wall is strongly recommended. The panels should not be pressed flush against the slope but installed with a minimal gap – this relieves stress on the connections.
