ᐅ Are there any installation tips for IKEA Platsa units when dealing with sloped ceilings?
Created on: 8 Apr 2023 19:17
Korhan
Hello everyone, I am currently planning an IKEA Platsa wardrobe for a room with a sloped ceiling. My question is: Are there any assembly tips that are especially helpful for installing Platsa units under sloped ceilings? I am particularly interested in how to best adapt the modules to the angled ceiling without having to do a lot of cutting or modifications. What experiences have you had to ensure the wardrobe is stable but still looks good? I look forward to your advice and practical tips, including any tricks that should not be forgotten.
edisondan
9 Apr 2023 07:22
The panels can be made from painted MDF or plywood sheets, which are easy to mill and saw. For mounting, a concealed system is recommended, such as mounting brackets or thin screws attached to the back of the panel and engaging with the cabinet carcasses. It is important to ensure precise measurements to avoid gaps. Since IKEA does not offer special components for sloped ceilings, custom sizing is the best solution. Alternatively, narrow edge strips can help visually integrate the panels with the Platsa style.
DEOLAU
9 Apr 2023 09:13
edisondan schrieb:
For fastening, a concealed system is recommended, such as mounting brackets or thin screws
I can only agree with that. For my Platsa under the sloped ceiling, I used very small, sturdy metal brackets installed inside – they are hardly visible but hold very well.
labar43
9 Apr 2023 12:48
It helped me to precisely measure the roof slope using a bevel gauge and then cut it with a very fine saw blade – it worked really well and wasn’t that difficult! If you make a wrong cut, don’t worry, at Platsa you can often save a lot with small adjustments. Don’t stress, every tip will help you move forward! 😊
narDietmar
10 Apr 2023 08:56
Additionally, I recommend always ensuring during installation that the cabinets are not only positioned but also properly aligned and leveled, as roof slopes can be irregular. A spirit level and a longer ruler or straightedge can help compensate for unevenness. Ventilation behind the cabinets should also be considered to prevent moisture damage. Local conditions can have a significant impact on stability and durability.
Korhan
10 Apr 2023 14:17
Thank you for your detailed contribution. I hadn’t considered ventilation at all. Is there a general rule of thumb for the minimum distance to leave from the wall or sloping ceiling, or is it more about overall air circulation in the area? Also, a quick question for everyone: do you use base plates or feet for Platsa units on sloped ceilings to compensate for uneven floors?
