I am planning to carry out some repairs on my IKEA Besta furniture. I have a question: which tools are useful and most effective considering the typical materials and fasteners used in Besta? I have heard that not only standard screwdrivers are needed, but possibly also special tools for fittings or for tightening dowels.
Since IKEA furniture often uses cam lock fittings, wood screws, and sometimes metal fittings, I am interested in whether special screwdriver bits, cordless drills, or felt pads to protect surfaces are recommended. Additionally, I would like to know if there are any particular tips for retightening screws without damaging the furniture material.
I look forward to specific recommendations, ideally with explanations of why certain tools are especially suitable.
For BESTA, you mainly need a good Phillips screwdriver (PH2) or, even better, a cordless drill with the appropriate bits.
- Cordless drill for quick assembly and disassembly
- Rubber mat protects the furniture during repairs
- A small hammer can sometimes be helpful for dowels
Special tools are rarely necessary; standard ones usually suffice.
The question is very relevant because IKEA BESTA systems are standardized, but small details in repairs are often underestimated.
Basically, I recommend the following tools and procedures:
- Phillips screwdriver PH2: This is the standard, as most cam lock screws or wood screws require it. A cordless drill with an adjustable torque setting is especially recommended here to avoid over-tightening screws.
- Allen keys (hex keys): Some fittings and legs use hex screws. IKEA often provides a small allen key, but a set with multiple sizes and good grips is helpful in the long term.
- Rubber mallet: To carefully adjust connectors or parts without causing damage.
- Felt pads or other soft surfaces: Especially when repairing on a table or floor, these protect against scratches.
Be careful with screwdriver speed and torque! Especially with chipboard or similar wood-based panels, too much force is counterproductive and can cause damage. If screws stick, it’s better to work with moderate force, turning in a jerky rather than continuous motion.
Regarding how to retighten screws without damaging the material: It helps to fully loosen the screw first and then retighten it evenly by hand, which reduces stress. If fasteners are stripped, wood glue and small wooden dowels can be used for reinforcement.
The quality of the screwdriver bits is important here—cheap tools often damage screw heads.
Hello Likeo,
I think your question is very well thought out, as some tools indeed make more sense than others depending on the exact repair needed.
In addition to a cordless screwdriver with appropriate bits, I would like to add:
- A set of precision Phillips and flathead screwdrivers alongside a PH2: Sometimes IKEA uses small screws for back panels or fittings.
- A small ratchet or bit screwdriver is also very helpful for tight spaces.
- If surface work is involved, plastic wedges for lifting or adjusting are useful.
- A folding ruler or tape measure is essential when aligning components.
I can only confirm that. In my experience, uneven tightening of cam locks often leads to wobbly furniture.
If you could specify which types of repairs you plan to do (securing screws, repairing veneer, adjusting hinges), I can offer more specific advice.
Nakar33 schrieb:
Regarding how to retighten screws without damaging the material: It helps to first loosen the screw completely and then tighten it evenly until snug by hand to reduce stress.
Here is a brief guide that I often use for repairs on IKEA BESTA furniture:
1. Preparation:
- Cover the work area with felt pads to protect the furniture.
- Prepare the necessary tools: Phillips PH2 screwdriver, hex key set (Allen keys), cordless drill with adjustable torque, rubber mallet.
2. Check and retighten screws:
- Do not simply tighten screws; first loosen them, then retighten evenly one by one.
- Check for damage to screw heads and clean gently with a fine file if necessary.
3. Inspect cam lock fittings:
- Check cam locks and dowels for a secure fit.
- If dowels are worn out, use wood glue and clamp them in place.
4. Hinges and fittings:
- Often require a hex key.
- Minor adjustment screws may also be small Phillips heads.
5. Protection tips:
- Avoid using the cordless drill at full speed to prevent damage to screw heads and materials.
- Gently clean screw holes if the material is fragile.
Summary: A good cordless drill with adjustable torque, suitable screwdrivers (PH2, hex keys), and protective materials are essential. Additionally, some wood glue and felt pads are very helpful.
I’m happy to answer any questions about alignment or specific damage.
1. Preparation:
5. Protection tips:
