ᐅ Which tools are especially useful for assembling Billy shelves?
Created on: 10 Mar 2021 08:07
FARBO2
FARBO2
10 Mar 2021 08:07
Hello everyone, I am planning to assemble some Billy shelves from Ikea soon and am wondering which tools are particularly helpful to work efficiently and minimize mistakes.
I understand that a screwdriver is necessary, but are there any specific or recommended tools that can significantly simplify the process?
For example, I have heard that a cordless drill is very useful, but which type would you recommend? Is it also necessary to pre-drill holes before screwing? Are there any tips or tricks where certain tools make a task easier?
I would appreciate your experiences, recommendations, and possibly any advice on common problems that can occur when using the wrong tools.
Leonardteo
10 Mar 2021 09:23
Basically, assembling the Ikea Billy bookcase is not complicated, but if you plan to build multiple units, using a cordless drill with the right Phillips bit is definitely worthwhile.
I recommend a cordless drill with adjustable torque to avoid overtightening or leaving the screws too loose. This helps prevent the chipboard from tearing out, which is often an issue.
I don’t see much point in using a drill to pre-drill the holes, since the Billy shelves usually come with pre-drilled holes. A simple screwdriver or the cordless drill is perfectly sufficient.
Landontau
10 Mar 2021 10:15
I would like to reply here with a short tutorial based on experience from assembling many Billy-style shelves:
1. Preparation: Make sure you have sorted all the parts and screws. It helps to have all your tools ready at hand.
2. Tools: A cordless drill is definitely the best companion. It saves time and effort, especially if you are assembling more than one shelf. Make sure to use a Phillips bit that fits the screws exactly to avoid damaging the screw heads.
3. During assembly: Work carefully and avoid over-tightening the screws – during my first assembly, I screwed them in too tightly, which caused slight damage to the edges.
4. Alternative: A standard Phillips screwdriver can also be used, but if you have several shelves to assemble, it will strain your arms over time.
In summary: Cordless drill + the right Phillips bit = optimal.
One small tip: If you are worried about splintering, you can gently clean the edges with sandpaper before screwing in.
Parbo
10 Mar 2021 11:42
Very interesting question, as assembling Billy shelves may seem simple at first glance but actually involves some pitfalls where the right tools can make all the difference.
I’d like to go into more detail about the individual tools I find especially useful:
- Cordless drill/driver: Essential due to its versatility. It’s important to have a model with adjustable torque, particularly because of the sensitive particleboard.
- Phillips screwdriver bits: Use high-quality bits that won’t wear out quickly. This prevents damage to the screw heads.
- Hammer: A rubber mallet is beneficial for installing the wooden dowels since it transfers force without damaging the material.
- Spirit level: Not directly for screwing, but useful to ensure the shelf is perfectly level after assembly.
- Measuring tape or folding rule: Handy if you are combining multiple shelves and need to maintain precise distances.
Regarding pre-drilling: Ikea often uses pre-drilled holes, so it’s usually not necessary. However, if you want to make custom adjustments, it’s advisable to use a thin drill bit that matches the screws exactly to avoid damaging the particleboard.
A quick question: Are your shelves already partially assembled, or are they new items to be fully built? Depending on this, clamps can be helpful to hold parts securely during screwing.
FARBO2
10 Mar 2021 12:03
Parbo schrieb:
Quick question: Are your shelves already pre-assembled, or are they brand new and need to be fully built?
Thank you for the detailed advice! These are completely new shelves that I will unpack and assemble myself. I have some clamp vises here, so I might try using them—thanks for the tip.
What is your opinion on universal tools like multi-tools or ratcheting screwdrivers? Are these useful for assembly, or are they a bit over the top?
Jamalli
10 Mar 2021 14:28
I would like to speak briefly in favor of the cordless screwdriver, but I also see certain limitations and counterarguments that should be considered.
Leonardteo schrieb:
Cordless screwdriver with variable torque, so you don’t overtighten the screws.
That is certainly true; however, especially with cheaper devices, precision is often lacking, which can unintentionally lead to material damage.
Furthermore, it should be noted that a cordless screwdriver is mainly useful for people with some experience – if you’re not confident, a high-quality manual screwdriver offers better control.
Landontau schrieb:
Make sure to use a Phillips bit that fits the screws exactly, to avoid damaging the heads.
I can only agree with that. I also think the choice of tool should depend on whether you’re assembling the shelf just once or multiple times (e.g., moving). For a one-time assembly, a standard set will usually suffice.
So my question to the original poster: Do you plan to assemble shelves regularly, or is this a one-time project?
