ᐅ What tips can help if Billy bookcase doors no longer close properly?
Created on: 12 Mar 2021 09:17
Benaurel
Benaurel
12 Mar 2021 09:17
I have been having an issue for some time with Billy cabinet doors (from the well-known furniture store) not closing properly. Specifically, the doors no longer hang correctly on the hinges, don’t close flush, or sometimes remain slightly open even though I close them fully. I have tried various adjustments, but these only provided short-term improvements. I understand that the problem may be related to the hinge settings, but I’m also wondering if material fatigue could be a factor or if there are other tricks that might help.
What tips or experiences do you have for getting Billy furniture doors to close properly again? Is it necessary to replace the hinges, or are there home remedies? And how can the adjustment be improved, especially if the screws have been loose before?
I look forward to your tips and answers!
pikin
12 Mar 2021 10:02
As Benaurel correctly pointed out, the most common reason for Billy doors not closing properly is suboptimal hinge adjustment. These pieces of furniture typically use simple but adjustable concealed hinges.
First, check that all screws are tightened firmly. Even slightly loose screws on the hinge can cause incorrect door positioning. If tightening the screws is not enough, the hinge can usually be adjusted along three axes using the built-in adjustment screws: height, depth, and lateral alignment.
A proven approach is:
1. Loosen all screws slightly to align the door.
2. Move the door into the desired position.
3. Tighten the screws and make fine adjustments.
Material fatigue is uncommon for Billy doors due to the MDF substrate material, unless there is excessive load or damage. If in doubt, the hinges can be replaced at relatively low cost if cracks or wear are noticeable.
Furthermore, I recommend applying a drop of lubricating oil to the hinges if the mechanism becomes stiff. Dust and dirt buildup can also cause issues.
BEATE
12 Mar 2021 11:11
pikin schrieb:
First, check that all screws are tight.
This is the most important point. Tighten the screws.
If the screws don’t help, replace the hinges. New ones are inexpensive and easy to change.
Oil or WD-40 often helps if the door sticks or is hard to open.
REOHEINRIC
13 Mar 2021 14:45
Benaurel schrieb:
I am also wondering if material fatigue might play a role or if other tricks could help.
Regarding material fatigue: The carcass and doors of a Billy-type furniture piece are mostly made of veneered particleboard or MDF. Material fatigue usually shows through swollen or broken screw holes, especially if moisture was involved.
You often notice this when screws no longer hold properly. In such cases, using wooden dowels or—better yet—pressing and redrilling with suitable repair kits can help.
pikin schrieb:
Recommends lubricant oil on hinges.
That makes sense, especially silicone spray. WD-40 is good for cleaning but not necessarily as a lubricant.
A practical guide to optimal door adjustment includes:
- Lateral adjustment: Lever toward the inside of the furniture so it sits flush with the carcass.
- Height adjustment: Changes the position at the hinges, ideal for compensating uneven floors.
- Depth/pressure adjustment: For the right pressure to ensure the door closes tightly without sticking.
By following these steps consistently, most problems can be solved without needing new materials.
Finally, if the doors still don’t close properly, bent or damaged hinges may be the cause. Those should then be replaced.
