ᐅ Which replacement parts are most commonly needed for Ikea Hemnes furniture?
Created on: 13 Nov 2022 08:17
KilebeHello everyone, I am interested in the topic of spare parts for the Ikea Hemnes range. Since I recently acquired some furniture pieces from the Hemnes series, I would like to know in advance which spare parts are most commonly needed. I am particularly curious if there are typical weak points with drawers, doors, or fittings that tend to wear out quickly. Additionally, I would like to know if spare parts are easy to reorder and if there are any general recommendations on which parts are best to keep in stock to be able to act quickly if needed. Who has experience with this and can share detailed information about which Hemnes spare parts you have needed and why? Thanks in advance for your helpful feedback!
FeAndreas113 Nov 2022 10:39Basically, I recommend paying close attention to the fittings on the drawers and doors of Ikea Hemnes furniture. In detail, I most frequently see the following parts needing replacement:
- Drawer slides and runners: The plastic glides or metal tracks show wear after heavy use, which affects the ease of opening and closing.
- Door hinges: These occasionally need adjustment or replacement because they can loosen or stick over time.
- Handles: With regular use, handles can break or become loose.
- Flip locks or magnetic catches on some models are also prone to issues.
It is important to check the exact variant of the Hemnes product you have, as replacement parts can depend on the model. Reordering parts from Ikea usually works easily, especially if you have the product number handy. I would especially recommend keeping a spare set of drawer slides in stock in case the smooth-release function decreases.
One more question for you: do you mainly use dressers, nightstands, or wardrobes from the Hemnes series? That would help to specify the most important spare parts more precisely.
Regardless of the specific Hemnes product, user experience shows that certain replacement parts are needed significantly more often:
- Hinges: These are high-wear components that require adjustment or replacement over time on Hemnes doors, as they can warp or become loose.
- Drawer slides and runners: Smooth and quiet operation depends on intact sliding elements, which can become scratched or broken after extended use.
- Handles and knobs: Frequent use can cause mechanical stress, occasionally leading to breakage or loss.
There are no notable weaknesses in other components such as back panels or main carcasses. Replacement parts can often be ordered directly from Ikea, with some also available through their customer service. Anyone using Hemnes furniture in daily life should keep in mind the option of easy retrofitting and respond promptly when initial issues occur to prevent further damage.
Hello Kilebe, I agree with the previous commenters but would like to offer you some additional tips. Hemnes furniture is solidly made, but there are recurring issues with the drawer systems:
- The runners, especially if made of plastic, tend to stretch out over several years. This can cause the drawers to stick.
- Door hinges need to be checked regularly, both for alignment and for possible material fatigue. I recommend replacing the hinges as needed rather than just tightening them, since that won’t fully solve the wear problem.
- Handles are sturdy but can break if force is applied improperly. Having spare knobs and handles is therefore a practical backup.
If you like, I can put together a small list of spare parts with order numbers that you can find directly at Ikea. Reordering usually works smoothly either in-store or by phone.
One question: How heavily do you use the furniture? Is it mainly in a private living area with moderate use, or are there children or frequent furniture moves that could accelerate wear?
