ᐅ How can IKEA Hemnes furniture be transported more easily?
Created on: 11 Apr 2024 09:37
Tansan30
Tansan30
11 Apr 2024 09:37
Hello everyone, I am currently looking into how to make transporting furniture from the IKEA Hemnes series easier. Especially with larger items like wardrobes or dressers, transport can often be quite complicated – involving heavy weight, bulky dimensions, and not always ideal separation of the individual parts. I am interested to know if anyone in the forum already has experience or tips on how to make transport more efficient, whether through the right tools, special preparation during disassembly, practical packing methods, or aids that significantly simplify handling. Are there perhaps tricks for breaking down the furniture into smaller, more manageable units without risking too much additional assembly work? I would be very grateful for any advice on particularly helpful techniques or experiences.
Filippo
11 Apr 2024 10:15
To make transporting IKEA’s Hemnes furniture easier, it’s useful to first understand the construction principles behind these pieces. Hemnes furniture is typically made from solid pine, which makes it relatively heavy. The first step should always be to disassemble as much as possible—such as removing doors, drawers, and shelves. People often underestimate how much weight they can save by doing this.
Here are some steps I recommend:
- Loosen all visible screws with the appropriate Allen key.
- Completely empty drawers and remove them, as this reduces not only weight but also volume.
- Take off doors; this makes the individual parts slimmer, which facilitates transport in a car or moving van.
- Make sure you have the assembly instructions handy in case you want to reassemble everything later.
Additionally, it helps to carefully protect the disassembled parts with blankets or bubble wrap to prevent damage during transport.
How large are the pieces of furniture you want to transport? I’m interested so I can tailor the advice even more precisely to the dimensions.
dijan
11 Apr 2024 10:44
Oh, I know this topic all too well! Hemnes furniture can be really heavy and bulky—as if IKEA sometimes deliberately built it to be that sturdy 😉. My tip for moving it is to stay calm and prepare everything carefully in advance.
A useful trick is to separate the components so they can be handled more easily individually, rather than carrying everything all at once.
I’ve also found that using moving aids or furniture dollies can work wonders when transporting heavy parts.
Labeling the individual pieces might also help so you don’t lose track during reassembly later—that can save you a lot of trouble.
And very importantly: having a reliable helper or even two to pitch in makes all the difference. Doing it alone can be really frustrating.
nojaus
11 Apr 2024 11:26
I completely understand your situation, Tansan30. I’ve personally had issues with heavy Hemnes wardrobes myself. It really helps to take things step by step and not rush, even when under time pressure.
Sometimes it also makes sense to partially disassemble the furniture – meaning not taking it completely apart, but just enough so it stays stable while becoming easier to handle. For example, removing the doors, as Filippo already mentioned, and keeping the main body mostly intact to avoid complications later on.
At times, I almost felt overwhelmed during the disassembly, but with some patience, it’s manageable. Maybe having a checklist to tick off during the process could help so you don’t lose track.
I think it’s great that you’re approaching this so methodically.
Blavin
11 Apr 2024 12:02
For optimizing transportation, a precise analysis of the furniture structure is necessary. Hemnes furniture is modular, so disassembly into individual parts is generally possible.
The following steps are recommended:
- Remove drawers and shelves to reduce weight
- Detach doors while taking hinges into account
- Dismantle any loosely attached back panels, if present, as these are often removed to simplify packaging
- Wrap individual parts with protective materials such as moving blankets
- Use furniture dollies or roller boards, especially for heavy, flat components
The goal should be to minimize the dimensions of each part so that transport can be carried out in the available vehicle. Careful consideration of the dimensions is essential for logistical planning of the transport.
Filippo
11 Apr 2024 13:41
Blavin schrieb:
Wrapping individual parts with protective materials like moving blankets
Exactly, protection is extremely important. I often go a step further: especially the edges of Hemnes furniture are delicate. Additional edge protection works well here—either foam profiles or even homemade padding from thick clothing or terry cloth towels.
Blavin schrieb:
Using furniture dollies or moving boards, especially for heavy, flat pieces
I want to emphasize this again because many underestimate it: with these aids, you don’t just shift weight onto wheels, but also make maneuvering through narrow hallways or stairwells much easier. Usually, a combination of good disassembly and the right transport aids is key.
How often and over what distances do you plan to move the furniture?
