ᐅ Which screws do I need for specific IKEA Metod connections?
Created on: 1 May 2024 08:42
Andrinla
I am currently working on a kitchen project using the Ikea METOD system and have questions about which screws are specifically required for the special connections in this system. I have already looked through the standard packages but find some connection points unclear or only general instructions provided in the manual.
Specifically, I am interested in:
- Which types and lengths of screws are best suited for connecting the carcasses to each other?
- Which screws are recommended for mounting the METOD cabinets to the wall to ensure maximum stability?
- Are there screws that should be used specifically for installing the drawer runners in the METOD system?
I want to make sure I use the correct screws since I want to avoid warped or unstable constructions. Maybe someone here has relevant experience or precise recommendations on which screws (type, length, diameter, material) are ideal for these specific METOD connections.
Thanks in advance for your support!
noge58
2 May 2024 08:28
Great topic, because the right screws are often underestimated! I really appreciate that Andrinla has thought this through so carefully. It truly makes a difference in stability.
From my own experience, I can say:
- Never use the cheapest screws! They break easily and start to rust.
- Galvanized screws are decent, but stainless steel is invaluable, especially if the kitchen is in a humid environment.
- For drawer slides, I always use the original screws, as every hole fits precisely down to the millimeter.
Forget the idea of having to improvise somewhere – use the right screws, and you’ll enjoy them for a long time! 🙂
lyndon
2 May 2024 10:52
To add to what has already been said, I would like to address screw strength, which is especially important for kitchens subjected to higher loads.
IKEA METOD typically uses screws with a strength class of 4.8 or higher. This means they provide sufficient tensile and shear strength to hold the furniture together durably.
For wall mounting, screws should be at least class 5.8, as they transfer the loads to the wall.
Those with some DIY experience can opt for screws with better mechanical properties, but it should be kept within reasonable limits to avoid damaging materials due to excessive force.
nubar
4 May 2024 14:06
I agree with the previous points and would like to add:
- When purchasing, make sure the screws have a countersunk head so they sit flush with the surface.
- The thread length should be matched to the material being joined: too short won’t hold, too long can damage the opposite side.
- Cam connectors are more expensive but clearly offer the advantage of being easily disassembled, which is very helpful if you need to remodel the kitchen later.
This makes it a reasonable compromise between ease of installation and stability.
Greglau
5 May 2024 09:21
For the cabinet carcasses, 4x30 mm (1/8 x 1 1/4 inch) chipboard screws are suitable, and for wall mounting, 6x60 mm (1/4 x 2 1/4 inch) screws with wall plugs are recommended. For drawers, use 3.5x20 mm (1/8 x 3/4 inch) screws. Cam connectors require 5x30 mm (3/16 x 1 1/4 inch) screws. Stainless steel screws are advisable in areas with moisture.
Nabla64
5 May 2024 10:35
Greglau schrieb:
For the carcass cabinets, 4x30 mm (approximately 1/8 x 1 1/4 inch) chipboard screws are suitable; for wall mounting, use 6x60 mm (approximately 1/4 x 2 1/4 inch) screws with wall plugs.
That is absolutely correct and summarizes it very well.
Greglau schrieb:
Cam connectors require 5x30 mm (approximately 3/16 x 1 1/4 inch) screws.
Yes, and it is important that these screws are not tightened too much in order to avoid damaging the threaded holes.
If anyone has further questions, just ask!
