ᐅ Which screws are best for long-term stability in Ikea PLATSA units?
Created on: 5 Dec 2020 08:13
Finan6
Hello everyone, I am currently looking into how to assemble Ikea Platsa furniture pieces so that they remain stable and durable over the long term. My specific question is: based on your experience, which types and sizes of screws are best suited to achieve the highest possible long-term stability for PLATSA furniture? I am particularly interested in whether the original screws are sufficient or if alternatives (such as higher-quality chipboard screws, wood screws, or even special fittings) are recommended. Additionally, any tips on the correct screwing techniques would be helpful, as I’ve often heard that the material is quite delicate and can be easily damaged. Thanks in advance for your detailed advice and experience!
RENMA schrieb:
Screws should not be too thick, as this can cause the particle board to split.I agree; the balance between screw diameter and material thickness is crucial. I would also recommend systematically assessing the loads acting on the piece of furniture. Depending on the situation, a combination of screws and additional fittings might be more effective than just using longer screws. Additionally, a detailed comparison with alternative furniture fittings would be worthwhile, since many consider the original screws only as a temporary solution.
I understand the strong need for stability when it comes to furniture—especially with Platsa units, which I often modify. I usually use the original screws but combine them with nail plates and brackets when I expect heavier loads or if the furniture is frequently moved. This gives me confidence that everything won’t become unstable quickly. Regarding the screws, I haven’t personally noticed a significant difference between the original and chipboard screws, but the extra reinforcement makes a big difference.
Alberto516 Dec 2020 12:05PEDRO40 schrieb:
That gives me a good feeling that nothing will shake so easily.Exactly – I often find that the psychological reassurance provided by the right screws and reinforcing elements is underestimated. Sometimes the original parts are not completely trusted, even though they are technically often sufficient, but long-term stability is more important than the initial appearance.
Thanks for the helpful contributions so far! I would like to clarify something: Are there any specific recommendations regarding the type of thread? I have heard that fine or coarse threaded screws can have various effects on durability depending on the type of particleboard. Is this relevant for PLATSA? Also, when using brackets or additional fittings, is there a difference in the type of screws that should be used? Anyone with hands-on experience using different combinations of screws and fittings is welcome to share.
Finan6 schrieb:
Are there any specific recommendations for the type of thread?Yes, indeed: For particle boards, coarse-thread chipboard screws are recommended because they embed better into the material and provide greater holding power. Fine threads are more suited for solid wood.
Regarding angle brackets and additional fittings: Generally, short, sturdy screws should be used since the fittings are metal and require different holding strength. The best choice for fittings are machine screws with matching nuts or special structural wood screws approved for metal fittings.
