ᐅ Which screwdriver is best suited for assembling the Kallax?
Created on: 29 Jul 2021 20:09
juzar49
I am planning to assemble an Ikea Kallax shelving unit and want to use the appropriate screwdriver for it. My specific question is: which screwdriver is best suited for assembling the Kallax unit, especially considering the included screws and the connecting hardware?
So far, I have often used Phillips screwdrivers, but I wonder if a common Phillips screwdriver is sufficient or if it is better to use a precisely matching Pozidriv or Torx screwdriver.
Has anyone had experience with assembling the Kallax and can offer recommendations that also focus on durability and preventing screw damage?
Thanks in advance for your tips!
Lamar
30 Jul 2021 08:23
juzar49 schrieb:
whether a handy hexagonal handle or a larger one with rubber grip is more suitable?
I would even go so far as to say: take the biggest one you can reasonably hold, with a rubber grip. A clear advantage for longer tasks, especially if you’re assembling the Kallax in multiple sections.
But honestly – a simple, inexpensive screwdriver does the job just as well. Sometimes these discussions make things unnecessarily complicated.
Declan55
30 Jul 2021 08:48
A larger handle with rubber definitely helps improve the grip while screwing! The plant sap also plays an important role! ;-)
It grips really well, prevents blisters, and makes screwing almost enjoyable.
And: You can easily clean-turn the Kallax without fear of slipping.
Good luck with the assembly!
draleo
30 Jul 2021 09:11
Briefly about the handle: I see an ergonomic profile with a non-slip surface as a significant advantage. This is especially helpful during the often extended screwdriving time involved in furniture assembly at home.
But be careful: A handle that is too large can become unwieldy and may cause over-tightening if too much force is applied.
juzar49
30 Jul 2021 12:42
One more detailed question: For the Kallax cam connectors, you rarely need a separate Allen key or a bit with an internal Torx. Are the usual turning motions with a PH2 screwdriver sufficient here, or is a different tool required?
If so, would a separate set be better?
Helga
30 Jul 2021 13:52
The cam fittings used in Kallax typically require a small hex key (Allen wrench) or a flat-blade adapter, which is included in the package.
A PH2 screwdriver bit alone is not sufficient here, as the cam nuts need a special locking mechanism that must be turned with a hex key or flat-blade bit.
Therefore, it is advisable to use the provided tool or have a suitable hex key ready. A separate miniature hex key set (size 4 or 5 mm) can be helpful.
KUDAISY
30 Jul 2021 14:29
juzar49 schrieb:
You rarely need a separate Allen key or bit with an internal star for the Kallax cam connectors
That’s correct.
Assembly of cam locks is usually done with a small Allen key or a suitable flathead or Phillips bit, depending on the model.
Tip: Most Ikea Kallax sets include a small matching tool – you might want to get one separately as a precaution if you assemble furniture often.
It is important to apply controlled torque here to avoid damaging the material.
