ᐅ Which screwdriver is best suited for assembling the Kallax?
Created on: 29 Jul 2021 20:09
juzar49
I am planning to assemble an Ikea Kallax shelving unit and want to use the appropriate screwdriver for it. My specific question is: which screwdriver is best suited for assembling the Kallax unit, especially considering the included screws and the connecting hardware?
So far, I have often used Phillips screwdrivers, but I wonder if a common Phillips screwdriver is sufficient or if it is better to use a precisely matching Pozidriv or Torx screwdriver.
Has anyone had experience with assembling the Kallax and can offer recommendations that also focus on durability and preventing screw damage?
Thanks in advance for your tips!
Declan55
29 Jul 2021 21:29
I just assembled the Kallax recently! 🙂
I used the Philips PH2 screwdriver bit because it was specifically recommended in the Ikea instructions.
Important: Don’t apply too much torque and avoid spontaneous actions with cordless drills, otherwise you can quickly end up with crooked screws or damage to the wood.
It worked perfectly for me!
Sebastianm
29 Jul 2021 21:43
Philips PH2 is sufficient; I always use it with my cordless screwdriver set to torque mode. Kallax isn’t assembled with high-quality screws, so no special bits are needed.
farGlen
29 Jul 2021 21:56
PH2 fits without any problems; I wouldn’t force anyone to use Torx or something more complex. Kallax is simple and straightforward in design.
juzar49
29 Jul 2021 22:12
Thank you for your feedback, especially the recommendations regarding the PH2.
Can anyone provide more information about the type of handle? I am considering whether a compact hexagonal handle or a larger one with rubber coating would be better suited for assembling the Kallax. It is important to me that you can apply good force when screwing without slipping or causing pain to the hands.
Helga
30 Jul 2021 07:39
juzar49 schrieb:
Can anyone add something about the type of handle?
From an ergonomic perspective, I recommend a screwdriver with a rubberized or at least non-slip handle, ideally shaped ergonomically to fit comfortably in the hand.
Since assembling Kallax requires some muscle power to tighten the screws properly, such a handle reduces fatigue and prevents slipping.
Classic hexagonal handles are sturdy but offer less comfort during extended work.
KUDAISY
30 Jul 2021 08:02
juzar49 schrieb:
It is important to me that you can transfer force well when screwing
In addition to Helena’s points:
Tips for choosing handles:
- A large rotary handle allows better force transmission during short, strong twisting motions.
- Softer materials on handles help prevent blisters.
- For users with smaller hands, a medium-sized handle can be better than an oversized one.
For assembling the Kallax: An ergonomic screwdriver with a soft grip fits well in the hand and helps protect the material by allowing controlled turning.
