ᐅ How to Reinforce a KALLAX Shelf to Hold More Weight – Any Suggestions?
Created on: 30 Nov 2016 08:43
ronda53
ronda53
30 Nov 2016 08:43
Hello everyone, I have an IKEA Kallax shelving unit that I would like to use for heavier items than originally intended. I am wondering how I can reinforce the Kallax unit afterward to support more weight without significantly changing its appearance or completely rebuilding the shelf. The main concern is the load capacity of the shelves and side panels, as I’ve noticed that under somewhat heavier loads, the shelves tend to sag or bend. Does anyone have tips on suitable materials or reinforcement methods that I can use to increase stability? Experiences with plywood panels, metal braces, or other types of reinforcement would be very helpful. Thanks in advance!
Danabla
30 Nov 2016 09:02
Basically, the KALLAX shelves are designed for moderate loads. To increase the load capacity, it is advisable to reinforce the existing shelves with additional cross braces or by strengthening the back panel. Specifically, metal brackets can be attached to the interior sides to provide extra support for the shelves. Alternatively, plywood panels with a minimum thickness of 18 mm (0.7 inches) can be used as replacement shelves, as they sag less. It is important to secure the shelves firmly and ensure rigidity at the side panels, for example with screws or corner connectors. These measures significantly increase the load capacity and prevent bending under load.
Kinbu
30 Nov 2016 09:27
I find the approach of adding extra reinforcement very sensible. To strengthen the floors, I often use a 12-15 mm (0.5-0.6 inch) thick plywood or MDF board, which I cut precisely and place on the existing shelf panel or even replace it entirely. Then I lightly sand the edges and paint them so that it is not visually distracting. Additionally, small metal brackets can be attached to the sides with wood screws to prevent sagging. It is also important to distribute the load evenly, as point loads are otherwise difficult to avoid. If the shelf unit is positioned against a wall, I would also recommend wall mounting, which significantly increases overall stability.
pautanner
30 Nov 2016 09:59
I agree with that and would like to add: If you want to change the appearance as little as possible, you can use flat steel reinforcements instead of visible metal brackets. These are attached to the underside of the shelves and are often only a few millimeters thick. They can also be painted to match the look. This way, the shelving becomes much stronger while remaining almost invisible visually. Maybe also consider a bit of DIY with wood glue and additional battens on the side panels – this creates solid extra strength and saves you from the annoying metal look ;-)
tutan
30 Nov 2016 10:16
Super interesting question, I love such upgrades! 🙂 I once reinforced a KALLAX myself using threaded rods by screwing them vertically through the shelf, which increased the tension. It may sound wild, but it was very stable! If you want to improve the load-bearing capacity of the side panels, adding an additional hidden back panel made of strong plywood can help a lot. This prevents the parts from bowing out, especially with wider shelves. One more tip: don’t skip wall mounting, even if the shelf is supposed to stand freely – that is often the factor that really improves stability.
JAPLO
30 Nov 2016 11:03
I consider metal brackets and reinforcement strips to be the most practical solution for KALLAX shelves to increase the load-bearing capacity of the boards. Plywood panels are preferable in terms of weight compared to MDF, as they sag less. Additionally, it is important to consider how the load is distributed: a point load on a single board can cause bending even if it is generally stable. Therefore, I recommend spreading loads over a larger area and avoiding stacking very heavy items. Wall fixings are also critical for the overall stability of the shelving system.
