ᐅ Which screw sets are recommended for repairing Ikea Besta units?
Created on: 12 Sep 2021 08:23
reokolby
reokolby
12 Sep 2021 08:23
Good morning everyone,
I am currently planning some repairs on my Ikea Besta furniture and am wondering which screw kits are best suited for this. Specifically, I need to reinforce the shelves and possibly make some adjustments to the hinges. Ikea often uses special connector fittings and somewhat unusual screw sizes, so I am looking for a set that covers not only the common screw types but also offers a good variety in length and thread shape.
Does anyone have experience or recommendations on which screw kits are suitable for repairing Ikea Besta furniture? Is it better to rely on original spare parts, or do third-party kits usually provide the right selection and quality?
I would greatly appreciate any tips and specific product recommendations.
rebufar
12 Sep 2021 11:47
reokolby schrieb:
Specifically, I am concerned with stabilizing shelving boards and possible hinge repairs.
I have to disagree here: If you choose only generic screw sets from hardware stores or various cheap kits for Ikea Besta, you will often be disappointed. Most common sets are not designed for the typical connectors used by Ikea. If anything, original Ikea accessories are preferable because only they guarantee the correct fit.
Quality and precise fit do come at a cost, but when repairing furniture that should last, it’s not wise to cut corners.
However, you should also take a closer look at Ikea’s own accessories, as the original range can be confusing and is not always intended for repairs – often, these are assembly kits for initial installation.
A combination of original parts and high-quality multiple screw sets with variable screw types can be useful, especially if you are replacing more than just the standard components.
Genevieve
13 Sep 2021 09:16
rebufar schrieb:
Most common sets are not designed for the typical Ikea fasteners.
Interesting perspective, but I would see it more nuanced. Indeed, some Ikea screws are special, but there are also universally usable screws, for example metric versions, which can easily be found in high-quality sets.
For repairs on Besta furniture, in my view it is crucial to choose a set that offers not only various screw lengths but also different head types (e.g., Torx, Phillips), since Ikea varies here.
Furthermore, it is important to assess screws not only by their dimensions but also by material quality. Cheap sets tend to be prone to rust or have soft metal, which is naturally not ideal for furniture.
Therefore, sets that at least offer hardened screws and come with a good screwdriver set are recommended.
Good repair sets usually include:
- Screws in various lengths and diameters (3–5 mm (0.12–0.20 inches) are typical)
- Different screw head types
- High-quality materials (e.g., stainless steel or galvanized steel)
Does anyone have specific product recommendations that meet these criteria?
Dopoki
14 Sep 2021 16:52
Genevieve schrieb:
Sets that at least include hardened screws and a good screwdriver set are therefore recommended.
I fully agree with that. Based on my research, the most commonly used screws for Ikea Besta repairs have metric threads M4 or M5. The length usually ranges between 16 and 35 mm (0.6 and 1.4 inches), depending on the specific application (carcass, back panel, hinges).
Ideal screw sets should meet the following criteria:
- Include M4 and M5 screws in various lengths
- Torx and Phillips heads, since Ikea often uses Torx
- High-quality manufacturing, corrosion protection (galvanized or stainless steel)
- Optional additional fasteners such as dowels or cam connectors
Original Ikea replacement parts are guaranteed to fit perfectly; however, there are also manufacturers offering screws of comparable quality at lower prices. It is important to pay attention to the detailed specifications when selecting sets—often the right combination of screw size and type is missing.
As an addition, I recommend a sturdy, ergonomic screwdriver with interchangeable bits, since repairs on Besta furniture often take place in hard-to-reach areas.
In conclusion: for a reliable repair, the combination of high-quality screws and appropriate tools is essential.
