ᐅ Which screws provide the best durability for Ikea Besta units?
Created on: 2 Sep 2023 09:17
popar
popar
2 Sep 2023 09:17
Hello everyone, I am currently facing the challenge of achieving the best possible durability when assembling my Ikea Besta shelving system. Specifically, I am interested in which screws provide the most stability and long-term load-bearing capacity, and whether there are alternatives to the original fasteners supplied that are significantly more robust. I have read that the screws in this series can sometimes be a bit weak, especially when the shelves carry heavier loads or are frequently reassembled. Which screws have you found to be reliable in this context? Are there particular types or materials you would recommend? Any advice on suitable screw specifications (e.g., diameter, length, material) or tips for proper installation would also be greatly appreciated. Thanks in advance!
INGRID34
2 Sep 2023 09:29
For Ikea Besta, the original Torx screws are usually sufficient. If you want more durability, I recommend stainless steel screws of the same size. It is important that the screws are not too long, as they can damage the material.
andre3
2 Sep 2023 10:05
In addition to INGRID34’s recommendation: The original screws used for Ikea Besta are usually galvanized, providing corrosion protection, which is important for durability. Stainless steel screws are more robust, but they can sometimes cause fit issues because the material is often a bit harder. It is also important to use the correct diameter, usually 4 mm (0.16 inches) for Besta, to ensure the screws hold securely without splitting the wood. I personally recommend Torx screws with fine threads, as they offer better holding power. Additionally, pre-drilling helps reduce stress on the material.
GALEO4
2 Sep 2023 10:38
I see this a bit differently. Of course, the original Ikea screws are not the pinnacle of durability — anyone who expects that is mistaken. For long-term use and stability, it’s definitely better to avoid the standard screws and use high-quality stainless steel chipboard screws instead. They’re a bit more expensive, but you get improved load distribution and corrosion resistance. Also: what’s the issue with using your own screws? If you rely solely on Ikea’s recommendations, you will likely end up with mediocre results. One more tip: a suitable screw type for Besta should be at least 5 mm (0.2 inches) thick to gain height for better load bearing.
Paxton38
2 Sep 2023 11:12
GALEO4 schrieb:
For long-term use and stability, you should definitely avoid standard stock screws and use high-quality stainless steel chipboard screws.
That’s a valid point. High-quality fine-thread chipboard screws undoubtedly improve the assembly reliability with Besta. Additionally, it is important to properly prepare the pilot holes — turning the screws too quickly or at an angle can cause the material to crack. From my experience, countersunk head screws are preferable because they sit flush and don’t catch on the material.
Jensson
2 Sep 2023 12:01
I would like to share a brief guide on how to select and use screws for Ikea Besta cabinets to achieve the best results:
- Screw type: Chipboard screws with fine threads, preferably stainless steel (for corrosion resistance and durability)
- Diameter: At least 4.5 mm (0.18 inches), preferably 5 mm (0.2 inches) to allow for higher load capacity
- Length: Depending on the thickness of the components, but not so long that the screw heads protrude on the opposite side
- Pre-drilling: Recommended for hard panels, for example with a wood drill bit about 70% of the screw diameter
- Driving: Use a Torx bit, which usually provides better grip than a Phillips head
Common mistakes include using screws that are too long, not pre-drilling, and incorrect torque application, all of which can cause material damage.
