ᐅ What screw lengths are optimal for different IKEA Platsa components?
Created on: 15 Feb 2020 17:09
Lihau
Lihau
15 Feb 2020 17:09
lately, I have assembled the IKEA Platsa series several times and noticed that choosing the right screw length is not always straightforward. My specific question is: Which screw lengths are optimal for the different Platsa components, such as the side panels, back panels, bottom boards, and doors?
I am especially interested in recommendations based on material thickness and load. For example, whether shorter screws should be used for the side panels to avoid screwing too deep and causing material damage, and if different lengths work better for the back panels.
Additionally, it would be helpful to know if there are specific screw lengths that have proven effective when attaching hinges and handles, to ensure stability without damaging the parts.
I look forward to your experiences and well-founded advice!
Raymond
15 Feb 2020 19:23
Hello Lihau,
regarding your question about the optimal screw lengths for various IKEA Platsa parts, I can provide you with detailed guidance. Fundamentally, it is important that the screw length is chosen so the materials are held together firmly without the screw penetrating too deeply and causing damage or splitting.
For the side panels of the Platsa cabinets, which are usually made from relatively thin particleboard, I recommend screws about 30 to 40 mm (1¼ to 1½ inches) long – this is generally enough to ensure a secure hold without going all the way through.
The back panel is thinner, typically a hardboard panel, so shorter screws around 15 to 20 mm (⅝ to ¾ inch) should be used here, since the back primarily provides stability but longer screws could damage the panel.
For the bottom parts, which bear more load, screws around 35 to 50 mm (1⅜ to 2 inches) are usually suitable. When installing hinges, you should use the screws that come with IKEA hardware, as these are specifically matched to the material thickness and hinge design – these screws are typically about 30 mm (1¼ inches) long.
Handle screws are typically about 25 to 30 mm (1 to 1¼ inches) long, ensuring the handles are firmly secured without penetrating the material.
I recommend always sticking to the manufacturer’s specified screw lengths when replacing screws or buying replacements from IKEA accessories, as material thicknesses are carefully matched.
Hope this helps!
tolokau
16 Feb 2020 08:46
Hello Lihau and Raymond,
I would approach the topic of screw lengths a bit more systematically and offer a kind of mini-guide focused on the most important Platsa components:
- Side panels: The base material here is particleboard about 16 mm (0.6 inches) thick. Screws with a diameter of 4 mm (0.16 inches) and a length of 35 mm (1.4 inches) work best. It is important not to screw too close to the edge to avoid splitting the material.
- Back panels: These are thin, usually 3 mm (0.12 inches) hardboard panels. IKEA typically uses pins or nails here. If screws are necessary, 15 mm (0.6 inches) length is enough to go through the material without penetrating too deeply.
- Shelves and intermediate shelves: These are more robust at about 16 mm (0.6 inches). Screws of 40–45 mm (1.6–1.8 inches) length are optimal as they provide solid connections and withstand loads.
- Doors and hinges: Hinges require special screws, usually 30 mm (1.2 inches) long, with depth carefully adjusted so they don’t screw in too deep and impair function. For handles, you should use the standard IKEA length, often 25–30 mm (1.0–1.2 inches).
Common mistakes I often see:
- Choosing screws that are too long: this can cause splitting and material damage.
- Screws that are too short: reduce stability and durability.
- Screws with the wrong diameter: screws too thin won’t hold, screws too thick damage the material.
In summary, I recommend starting with screws about 35 mm (1.4 inches) long for the main components and adjusting as needed.
Also: for best durability, always pre-drill if the material is very hard or if you are unsure.
Good luck with your assembly!
Raymond
16 Feb 2020 14:31
tolokau schrieb:
Choosing screws that are too long can cause splitting and material failure.
This is a very important point. I would like to add that especially with panel materials such as particle board or hardboard, using screws that are too long can cause the panel to split. This often only becomes visible after the furniture is already under load.
tolokau schrieb:
For the best durability, always pre-drill if the material is very hard or if you are unsure.
Pre-drilling also helps prevent material breakage and makes screwing easier. Many users underestimate this. It is advisable, especially for thicker parts or when making modifications later, to use a drill bit just slightly smaller than the screw diameter.
Furthermore:
- When installing hinges, always use the screws supplied by IKEA, as the thread and length are optimized for the hinge and panel thickness.
- For handles, metric screws with a 4mm diameter and the appropriate length can be used if the original screws are missing.
I hope this complements the previous advice well and emphasizes preserving the material.
Best regards!
