ᐅ Which types of paint are suitable for creating a durable and long-lasting surface on Ikea Besta units?
Created on: 26 Oct 2021 14:07
MikagauHello everyone,
Over the past few weeks, I have been considering how to make my Ikea Besta furniture pieces durable and resistant to scratches, moisture, and everyday wear. My specific question is: Which types of paint or coating are best suited to achieve an especially tough and long-lasting surface on the Besta fronts and carcasses?
It is important to me that the coating not only looks good but also withstands mechanical stress and is as resistant as possible to grease, water, and minor impacts. I have looked into different types of coatings such as acrylic paints, polyurethane (PU) coatings, and alkyd resin paints, but I am unsure which one is particularly recommended, especially in combination with the surface characteristics of Besta (usually particleboard with a melamine finish).
Additionally, I am interested in whether any special pretreatments are necessary, such as priming or sanding between coats, to ensure optimal adhesion and durability. I look forward to your experiences and tips on which type of coating and approach you would recommend for achieving a particularly robust surface on Ikea Besta.
Thierryzar26 Oct 2021 14:59For Ikea Besta, I recommend ready-to-use two-component polyurethane lacquer. It is durable and highly resistant to scratches and moisture.
Before applying, you should lightly sand the surface to ensure adhesion. Priming is usually necessary for melamine-coated surfaces.
To add some points about choosing paints for Ikea Besta:
- Since Besta furniture is often made from particleboard with a melamine or plastic coating, paint adhesion is more challenging compared to raw wood surfaces. A thorough pretreatment such as sanding and using special primers (e.g., adhesion promoters for plastics) is essential.
- Two-component polyurethane (PU) paints offer excellent resistance to mechanical wear, chemicals, and moisture. Therefore, they are the best choice for durable furniture surfaces in the long term.
- Acrylic paints are easier to apply and less harmful to health but may wear out faster under heavy use.
- Alkyd paints are also durable but are often seen as an older standard and have disadvantages in terms of odor and application compared to modern PU paints.
Recommendation: Apply a primer on the lightly sanded surface, then two coats of 2K PU paint. Sanding between coats significantly improves the final result. This way, you achieve the best combination of durability and appearance.
Thierryzar schrieb:
For Ikea Besta, I recommend ready-to-use two-component polyurethane varnish. It is durable and resists scratches and moisture very well.Of course, that is the classic recommendation, but is it really the holy grail? I think many overestimate the importance of the varnish: perfect preparation and the right working conditions are often much more crucial than the type of varnish itself.
And honestly, with Ikea Besta we are talking about furniture that is often used daily; a two-component varnish is certainly a good solution but involves a lot of effort that not everyone can manage.
I suggest also considering durable acrylic varnishes. These are easier to apply, dry faster, and can be sufficiently resistant when applied in multiple coats—especially if you don’t expect high-end furniture but want to protect items for everyday use.
Additionally, it is always worth questioning whether varnish protection can be supplemented with an extra foil or protective layer—sometimes that is the smartest solution alongside the varnish.
