ᐅ Which type of paint products are better suited for Ikea Besta – acrylic or oil-based?
Created on: 11 Nov 2022 09:13
LaurinHello everyone, I am currently planning to refresh my Ikea Besta furniture and am considering which type of paint would be better suited for this – acrylic or oil-based paint? It is important to me that the surface is durable, resistant to scratches and moisture, and as easy to clean as possible. At the same time, I would like a nice matte to satin finish that does not yellow or lose its gloss too quickly. Does anyone have experience with the differences between acrylic and oil-based paint specifically for furniture like the Besta series? Which paint products have proven effective in practice, and are there clear advantages or disadvantages when using one or the other? I would appreciate any experiences, tips for preparation, and application!
Hello Laurin, your question is very detailed and shows that you have already given it some thought. Basically, acrylic paints are water-based, dry faster, and have a less strong odor, which makes working with them more pleasant. They offer good scratch resistance but can sometimes be less flexible than oil-based paints, which contain solvents and can have a slightly more nourishing effect on the wood itself.
For Ikea Besta, which is usually made from particleboard with foil or melamine coating, acrylic paint is often the better choice because it adheres better without damaging the surface. Oil-based paint can create a more beautiful, warm tone on furniture with wood content. Preparation is important: sanding, cleaning, and possibly priming when using acrylic.
So, if the piece of furniture will be used heavily and you want quick drying, go with acrylic. For a more elegant look with a natural effect, oil-based paint might be better, but it comes with longer drying time and stronger odor.
For reference: Ikea Besta furniture is usually made from particleboard with melamine or foil surfaces, which are plastic-based. Acrylic paint is advantageous here because it adheres well to these substrates and causes fewer chemical reactions.
Oil-based paint, on the other hand, is typically designed for solid wood and penetrates the material, which does not work with particleboard. Additionally, there is a risk that the finish will peel off or become uneven on foil coverings.
Summary:
- Acrylic paint: good adhesion, fast drying, durable, suitable for coated surfaces
- Oil-based paint: nourishing for wood, longer drying time, not ideal for foil coatings
Therefore, I clearly recommend acrylic paint for Besta.
Summary:
KARJU schrieb:
Acrylic paint: good adhesion, fast drying, durable, suitable for coated surfacesThere is little to add to that. However, it is important to lightly sand and clean the surface before painting to ensure optimal adhesion. I also recommend choosing a paint with UV protection to prevent color changes. Regarding cleaning, acrylic paints are generally more resistant to common household cleaners than oil-based paints.
When used in living areas or kitchens, the practical benefits of acrylic paint become evident.
Tevin schrieb:
Acrylic paints are water-based, dry faster, and have a less intense odor, which makes working with them more pleasant.Thanks for the insights! I have a question regarding durability: How do acrylic paints hold up against stronger cleaners or heavy wear in households with children? Do acrylic paints withstand more intense mechanical stress over the long term, or is oil-based paint actually more durable despite its longer drying time?
I’m not looking to simulate heavy use, but a certain level of durability is important to me. What are your thoughts on this aspect for the two types of paint?
