ᐅ Which modular systems can I create with IKEA Besta for flexible storage solutions?
Created on: 27 Dec 2022 16:24
Yakupda51
Yakupda51
27 Dec 2022 16:24
I recently looked into several IKEA Besta units to create flexible storage in my living room. Since I need the furniture in my apartment to be adaptable to changing needs, I’m interested in which modular systems can specifically be implemented with IKEA Besta.
What combinations are possible when using different sizes, doors, drawers, and inserts? Are there any recommended extensions or additions from other IKEA ranges that work well with Besta to make storage flexible and versatile?
I would appreciate detailed tips or even examples of how you use Besta modularly and whether there are any technical details or pitfalls to watch out for.
Laukau5
27 Dec 2022 18:57
Hello Yakupda51,
Your question about the modular possibilities with IKEA Besta is really interesting and deserves a detailed answer, as Besta is one of the flexible systems that can be used far beyond simple storage.
First of all, Besta basically offers three standard frame widths (60 cm, 120 cm, and 180 cm) that each come in different heights (38 cm, 64 cm, 91 cm, and 128 cm). These dimensions allow the system to be combined freely both horizontally and vertically.
- The modules can be fitted with different fronts: doors, drawers, or open compartments. The key factor here is whether you want to "hide" storage (e.g., with doors) or need quick access (drawers).
- The system becomes especially interesting with additional interior fittings: adjustable shelves can be moved vertically, interior boxes help organize, and there are even pull-outs for bottles or multimedia equipment.
- From a technical perspective, you should note that stability may need to be reinforced with additional fittings as the height increases, to prevent the modules from wobbling or tipping when mounted on the wall or stacked.
- Add-ons from other IKEA ranges, which often integrate seamlessly with Besta, include drawer inserts from IKEA Alex or VARIERA organizing systems. Some also use skirting boards and IKEA smart lighting to make the system feel more homely and functional.
If you provide me with your exact room dimensions and intended use, I can also give you some specific planning tips. For example, are you planning to use the Besta more as a lowboard, sideboard, or shelving unit? Should it also serve as a room divider? The more details you give, the better we can explore the modular options.
I hope this introduction helps you design your storage space flexibly according to your needs.
notupra
27 Dec 2022 19:43
With Besta, you can combine different modules with doors and drawers and flexibly stack or place them side by side.
Tip: Use interior drawers and shelves to organize storage space optimally.
tyson51
28 Dec 2022 10:15
Yakupda51 schrieb:
What combinations are possible when using different sizes, doors, drawers, and inserts? Are there recommended extensions or additions from other IKEA series that work well with Besta to create flexible and versatile storage?
It is important to consider the intended use when planning. For living rooms and multimedia setups, I recommend Besta combinations with cable management openings and open compartments, which help store and ventilate electronic devices effectively.
In particular, Variera boxes and drawer inserts are good additions to keep things organized. You can also choose doors with soft-close hinges, which significantly improve everyday usability.
From a technical point of view, the orientation of the modules is also important: when combining multiple units, you should use extra connectors or brackets for added stability. This prevents unwanted shifting, especially if drawers are used frequently.
In my experience, using Besta together with shelves from the Pax series works well, as they increase load capacity if needed and offer more flexibility.
In summary: plan the modules according to your storage priorities, use suitable inserts, and consider mechanical stability when combining more than two units.
semuneo
28 Dec 2022 11:29
I fully understand how important flexible storage is, especially when you have constantly changing furniture needs.
Laukau5 schrieb:
The more specific you are, the better you can explore modularity.
I find this statement very fitting because it really helps to carefully consider your own situation.
Personally, my experience with Besta has shown me that it’s not just about storage, but also about visually organizing the space in a pleasant way. Especially in small rooms, the chosen system can help create a sense of order and clarity that feels very relaxing.
If you’re unsure, you might want to start with a small combination and add to it gradually. This also reduces stress during the planning phase and gives you more freedom to adapt the system without committing to a fixed configuration.
Laukau5
29 Dec 2022 09:02
tyson51 schrieb:
The orientation of the modules is also technically important: When combining multiple units, you should use additional connectors or brackets for increased stability.
At this point, I would like to add that when combining Besta modules not only side by side but also stacked, it is crucial to observe the maximum load capacity. The IKEA instructions provide specific values that should definitely be taken seriously to ensure long-term stability of the system and to prevent accidents.
I also recommend considering the use of wall mounts not only for tall but also for wider cabinets whenever possible. This reduces the risk of tipping, especially around children or when heavy items are stored.
Another practical idea is installing LED strips in the open compartments. This not only makes the units look more modern but also adds functionality by allowing you to see what’s inside quickly without needing additional lighting.
One more question for you, Yakupda51: Do you use Besta modules in other rooms, for example the kitchen or home office, or is your focus mainly on the living room and hallway?
