ᐅ Which materials are suitable for repairing IKEA HEMNES furniture?
Created on: 19 Apr 2021 08:32
narnar
narnar
19 Apr 2021 08:32
Hello everyone, I would like to use this thread to discuss which materials are best suited for repairing IKEA Hemnes furniture.
Specifically, I am interested in fixing minor damages such as scratches, broken corners, or slight deformations in the wood or wood-based materials. A particular challenge with Hemnes is that the furniture is made from solid pine wood, but depending on the model, the surface can be either painted or oiled.
I am looking for durable and visually appealing repair solutions that can be applied by DIY enthusiasts without professional tools and using readily available materials. Which adhesives, fillers, wood putties, or finishes are suitable for this? Are there differences depending on the type of damage?
Additionally, it would be helpful to know which preparation steps are recommended to achieve the best results—for example, sanding, priming, or which products should be avoided because they are incompatible with the Hemnes surface.
I look forward to your experiences, tips, and material suggestions—including recommendations on where to obtain these products. Thanks in advance!
kibutar
19 Apr 2021 11:43
narnar schrieb:
A special challenge with HEMNES is that the furniture is made from solid pine, but the surface can be either painted or oiled, depending on the model.
This is exactly where the difficulty lies when repairing this furniture. Pine is a softwood, so it tends to dent and scratch from impacts, and the surface finish plays a major role in achieving a clean result.
For minor scratches on the painted version, I recommend using wood repair wax or color-matched wax sticks, which can be found at hardware stores. These can be melted or rubbed into the damage and then sealed. A very important—and often underestimated—step is to gently polish afterwards with fine steel wool (0000 grade) or very fine sandpaper to make the repair blend in seamlessly.
For broken corners or larger defects, two things should be kept in mind:
- First, the broken part must be glued together with a high-quality wood glue suitable for solid wood (e.g., D3 or D4 rated, as these are water-resistant and very strong).
- Then, a high-quality wood-based filler should be used to fill any gaps; avoid mineral-based fillers as they may crack or lift later.
If the surface is oiled, I strongly recommend using only compatible oils or waxes. Paints can be problematic here because they do not harmonize with the original finish and might peel off.
Have you already identified the type of surface on your furniture piece and the exact nature of the damage? This is not entirely clear from your description and would help provide a more precise recommendation.
hauklo
20 Apr 2021 07:18
kibutar schrieb:
For minor scratches on painted surfaces, I recommend wood repair wax or color-matched wax sticks
I can confirm that. I would systematically differentiate at this point:
- For no or barely visible surface damage, I often use color-matched repair waxes or wax sticks. These are relatively inexpensive, easy to apply, and, most importantly, reversible.
- For deeper damage or broken parts, structured wood fillers compatible with the furniture structure should be used. Good adhesion is important – polyurethane wood fillers work very well here, as they hardly shrink and are sufficiently flexible.
- Always make sure the material matches both the wood grain and the surface treatment. For oiled surfaces, re-oiling after repair is essential.
For glue, I use only waterproof wood glues of the D3/D4 class, as they withstand changes in moisture without swelling.
Finally, a fine sandpaper (grit 240 or finer) should always be used to blend the surface.
Recommended manufacturers for these materials include Bona, Clou, or Osmo, as they also offer products for the maintenance of oiled wood surfaces.
How large are the damages and on what type of surface will the repairs be carried out?
floga
20 Apr 2021 22:07
I understand that with a piece of furniture like the HEMNES, which is used daily by many families, you want a sturdy and as discreet as possible repair.
narnar schrieb:
A particular challenge with HEMNES is that the furniture is made of solid pine, but depending on the model, the surface can be either painted or oiled.
I also found it helpful to first properly assess the surface before just starting to glue or fill. With my HEMNES display cabinet, I had both deformations in the pine wood and scratches on the painted surface.
Here’s how I proceeded: I lightly sanded the damaged area with 240-grit sandpaper, then used some veneer filler that I was able to color-match quite well, and after it dried, I coated everything with a suitable wood varnish. I noticed that you really only need very thin layers of varnish, otherwise the color difference becomes visible quickly.
Even though the repair isn’t completely invisible, I was very surprised by the result—especially since I am not a professional. So my tip would be to test on an inconspicuous spot first.
Has anyone else had experience with repair putty versus wax? Which finish did you find to be more durable or easier to maintain?
TANNAU
21 Apr 2021 09:51
Wood glue D3 or D4 for joints.
Repair wax for minor scratches on painted surfaces.
Use only compatible oil on oiled surfaces.
Light sanding with fine grit paper before treatment.
Wood-based filler, not mineral-based.
That’s sufficient.
