ᐅ Which Ikea Pax options are especially cost-effective?
Created on: 18 Apr 2019 09:17
Jeti36
Jeti36
18 Apr 2019 09:17
Hello everyone, I am currently planning to get an Ikea Pax wardrobe and am trying to find a cost-effective model that still offers enough storage space and decent quality. Therefore, I am interested in which Ikea Pax variants are particularly affordable, especially considering standard dimensions and commonly used layouts. It would be great if you could share your experiences and tips on budget-friendly combinations or options, whether regarding the carcass types, doors, interior fittings, or other components to consider when setting up an affordable but functional Pax solution. Thanks in advance!
Samuel
18 Apr 2019 11:22
Hey Jeti36, great question! 😃 When looking at costs, the simple option with white carcasses usually makes the most sense. These are often a bit cheaper than special finishes or wood-look surfaces. Also, you can save quite a bit with sliding doors if you don’t want expensive glass or mirrored doors – standard fronts tend to be more reasonably priced. A little tip: sometimes you can find discounted or clearance models, so you can put together classic PAX units that fit your needs without breaking the bank. For the interior fittings, it’s sometimes worth skipping pricey drawer or pull-out systems and opting for simple shelves and clothes rails instead. Overall, there are plenty of ways to save money while still creating useful storage space. Good luck with building your wardrobe! 😉
chenValeri
18 Apr 2019 13:09
Keep an eye on the 50x58x201 cm (20x23x79 inches) models. They are often cheaper than the larger 100 cm (39 inches) wide ones. And for doors: just buy plain matte white, it saves a lot.
Genevieve
19 Apr 2019 08:53
Interesting question, Jeti36. However, I would suggest considering the long-term use when it comes to cost-effectiveness. "Especially affordable" should not necessarily mean that you end up having to retrofit or replace multiple times due to poor initial choices. The Pax models with a 50 cm (20 inch) width are generally less expensive than the wider ones, but in some cases, the total cost can increase due to the number of components, which reduces the supposed advantage. You should also specifically consider the durability of the doors: cheaper fronts made from thinner materials may be more prone to damage, leading to additional costs later on. Therefore, it’s worth finding a compromise between budget and durability here. Do you already have more detailed price comparisons or sources for specific versions?
Samuel
19 Apr 2019 10:46
Genevieve schrieb:
"Especially low cost" doesn’t necessarily mean you’ll end up having to retrofit or replace multiple times due to poor purchases.
Absolutely right! I would even add that sometimes it’s smarter to invest a bit more in a sturdy model to enjoy your wardrobe longer. But hey, especially if you tend to rearrange or move often, budget-friendly Pax-type options can be a great starting point. The key is to choose the right model for your needs and simply be aware of what you’re sacrificing. Either way, there’s no need to stress too much—a wardrobe isn’t set in stone 😉
plopra
20 Apr 2019 07:34
50cm (20 inches) wide, 201cm (79 inches) high, the white cabinets are the most affordable standard. Doors in white, without glass or mirrors, are also less expensive. Interior fittings can be added as needed.
