ᐅ Which Ikea Pax models offer the most storage space?
Created on: 17 May 2020 09:37
Lopudra
Lopudra
17 May 2020 09:37
Hello everyone, I would like to ask the following question: Which Ikea Pax models offer the most storage space? I am planning to buy a large wardrobe and am focusing on the Pax system because it is flexible and modular. What matters most to me is a model that provides the maximum storage volume without compromising too much on depth or width – in other words, as much usable space as possible for clothes, shoes, and accessories. Are there specific sizes or variations that stand out significantly in terms of dimensions? Perhaps also with compatible inserts that optimize space usage? I would appreciate detailed experiences or specific recommendations, including comparisons between the common Pax versions. Thanks in advance!
bauku
17 May 2020 10:12
Great topic! 😃 For maximum storage, I definitely recommend the Pax depth of 58 cm (23 inches), so the deeper models rather than the 35 cm (14 inches) variants. You can choose a height of up to 236 cm (93 inches) – this makes the best use of the room height!
An ideal combination is widths of 100 cm (39 inches) and 150 cm (59 inches), since 50 cm (20 inches) doors don’t provide much storage. Also, I highly suggest using shelves, drawers, and internal fittings like baskets to make the most of every corner!
I have a 150 cm (59 inches) wide, 58 cm (23 inches) deep, and 236 cm (93 inches) tall Pax myself – it really fits everything, from shoeboxes to winter coats! Simply great, I can only recommend it. Good luck with your project!
elliot
18 May 2020 15:03
bauku schrieb:
For maximum storage space, I definitely recommend the Pax depth of 58 cm (23 inches), meaning the deeper models rather than the 35 cm (14 inches) variants.
As a supplement: The adjustable interior fittings are very practical but can partially reduce usable storage space due to built-in wooden components. Therefore, when deciding, it is important to distinguish the pure volume of the base models from the usable volume depending on the interior configuration.
Pax models with a height of 236 cm (93 inches), depth of 58 cm (23 inches), and widths of 100 cm (39 inches) or 150 cm (59 inches) offer the largest total volume. It should be noted that the standard frames are 75 cm (30 inches), 50 cm (20 inches), and 100 cm (39 inches) wide, with combinations of these creating the maximum width.
Additionally, frameless variants stand out because they often require less space on the sides, thereby providing more usable width in the room. However, these models are not always available in all heights.
enrique7
19 May 2020 18:45
I would like to raise a critical question: Is the largest volume necessarily the best storage space for everyone?
elliot schrieb:
The customizable interior fittings are very practical but partly reduce usable storage space due to built-in wooden components.
That sums it up well. Size alone isn’t everything – the layout and adaptability are crucial. Sometimes smaller units with smart inserts offer more effective storage, especially when you want to store accessories or items of various sizes.
Therefore, it’s important not only to consider the dimensions but also how the interior elements are designed. Are there any recent experiences on this? Does anyone have figures or comparisons regarding the actual usable storage space of the different configurations? I suspect that Pax models with many drawers might be better organized but possibly offer less total volume.
mifra
20 May 2020 11:22
enrique7 schrieb:
Size alone is not everything – the layout and adaptability are essential.
Exactly. An objective assessment makes sense:
- The largest Pax models are 236 cm (93 inches) high and 58 cm (23 inches) deep. Widths of 100 cm (39 inches), 150 cm (59 inches), or combinations thereof provide the greatest overall storage space.
- The combination of interior fittings (e.g., drawers, shelves, clothing rods) affects the effective storage capacity. Drawers reduce the usable shelf height but are advantageous for small items.
- The choice between frameless and framed models influences the wall space required.
- Special inserts such as trouser racks or shoe storage can better organize the volume.
For pure volume maximization, the 58 cm (23 inches) deep frames with 236 cm (93 inches) height are unbeatable. Interior fittings should be designed to be as flexible as possible according to needs.
Practical recommendation: measure the room, define storage needs, and consider not only external dimensions but also sensible interior planning.
