Hello everyone, I’m planning to buy one of Ikea’s Pax wardrobe systems, but I’m unsure which model offers the best quality. I’m mainly interested in durable materials, sturdy construction, and overall good workmanship, as I want to use the wardrobe for a long time. Maybe you have experience with the different versions, for example regarding the doors (sliding doors vs. hinged doors) or the interior fittings? Which Ikea Pax models really offer the best quality, and what should I pay attention to when purchasing to ensure long-lasting satisfaction with the wardrobe? Looking forward to your tips and experiences!
izak36 schrieb:
My main concern is durable materials, sturdy construction, and generally good workmanship, as I want to use the wardrobe for a long time.That’s really an important point you raise. I initially had some doubts myself about whether the Pax models could hold up in the long term. For me, it turned out that the models with firmer carcass panels and metal reinforcements are significantly more stable. For example, I chose the model with hinged doors because the sliding doors became a bit stiff after some time.
But especially if you know the wardrobe will be used a lot, I recommend investing additionally in interior fittings with sturdy shelves and metal clothing rails. That really makes a difference. I hope you find the model that suits your needs – sometimes spending a few extra dollars on accessories can noticeably extend the service life.
boelnu schrieb:
For example, I chose the model with hinged doors because the sliding doors became a bit stiff after some time.I can confirm that observation and would like to add some details regarding the quality of the Ikea PAX models:
- Cabinet materials: The cabinets are typically made of coated particleboard, with a load capacity of about 15–20 kg (33–44 lbs) per shelf, depending on the model.
- Doors: Hinged doors have sturdy hinges and generally offer greater durability than sliding doors, whose track systems can be more prone to wear.
- Units with metal frames or additional reinforcements are recommended for heavier use.
Quality varies significantly depending on the configuration; to achieve the best durability, the model with a metal clothes rail and fixed shelves combined with hinged doors is the most long-lasting.
While differences in workmanship between PAX models are not drastic, the choice of doors and suitable interior fittings makes the decisive difference.
Keatondra19 Jul 2023 08:12I would like to add something because the quality of Ikea PAX is often viewed differently:
- Stability also depends greatly on proper assembly. It is worth carefully and patiently following the instructions and, if necessary, using additional screws.
- Doors: Hinged doors are easier to maintain, especially if you have pets or children. Sliding doors save space but require clean tracks and occasional maintenance.
- Interior fittings such as metal drawers usually offer more durability than plastic versions.
I also recommend considering the series with metal frames, if available, as these tend to be more robust.
And if you are thinking about securing the wardrobe to the wall: definitely do it! This significantly increases safety and stability.
If you like, I can also send you a checklist for assembly quality.
Keatondra schrieb:
Stability also depends heavily on proper installation.This is a crucial point. Professional or at least very careful installation is essential to fully utilize the already good basic quality of the Pax models.
To summarize the model options:
- For maximum stability, a combination of a solid carcass with reinforced shelves and hinged doors equipped with sturdy hinges is recommended.
- Sliding doors are great for tight spaces but tend to be more prone to wear on rollers and tracks.
- Models with metal frames or reinforced side panels provide even greater stability.
My recommendation for users with consistently heavy loads is therefore Pax with hinged doors, reinforced interior fittings, and careful attachment to the wall. This ensures the best possible quality within the Ikea range.
