ᐅ Which Ikea PAX models feature especially quiet sliding doors?
Created on: 7 Aug 2015 19:37
faabram37F
faabram377 Aug 2015 19:37Hello everyone,
I am considering getting an IKEA PAX wardrobe with sliding doors because I want to save space in my bedroom, and I find sliding doors more practical than hinged doors. My main concern, however, is that the sliding doors are as quiet and smooth to operate as possible since I will be using the wardrobe at night and loud noises would bother me.
Does anyone know of specific models or versions of the PAX series where the sliding doors run especially quietly? Are there differences in the tracks, door panels, or installation methods that I should be aware of?
I’m really looking forward to your experiences and tips!
Hello faabram37,
Regarding your question about the smoothness of sliding doors in IKEA PAX, there are indeed some relevant differences. It is important to know that PAX sliding doors are generally based on different track systems.
- The standard PAX sliding doors use rollers running on aluminum tracks.
- The more expensive options, such as those with a soft-close feature, use dampers and optimized roller mechanisms to ensure quieter closing.
- Additionally, the type of door panel makes a difference: glass or mirrored doors tend to amplify less noise than wooden doors.
A tip: If smooth and quiet operation is important to you, you should definitely consider the soft-close tracks from IKEA, which are also available as a retrofit option. These offer significantly quieter movement during closing and opening.
In summary:
- PAX sliding doors with soft-close tracks
- Glass or mirrored doors instead of wood
- Regular maintenance and lubrication of the tracks
This combination usually provides the best noise reduction. I recommend checking the tracks in the store and testing the sliding motion before purchase.
In summary:
chenlen schrieb:
- PAX sliding doors with soft-close runnersAdditionally, I can explain in more detail how the soft-close runners work and what to pay attention to:
These special runners absorb the kinetic energy when closing the doors by using built-in dampers to gradually convert the motion energy, thereby reducing noise and impact.
A common mistake is that some users do not adjust the sliding doors properly. Even small inaccuracies during installation or uneven floors can lead to increased noise levels.
So, if you value especially quiet PAX sliding doors, I recommend:
- Using the original IKEA soft-close runners
- Precise alignment and adjustment of the doors following the instructions
- Checking that the runners are smooth and clean (dirt increases friction and noise)
Here is a brief step-by-step tip:
1. Install the doors according to the instructions with the soft-close system
2. Check the floor for levelness and correct it with shims if needed
3. Adjust the doors at the adjustment screws for smooth operation
4. Lubricate the runners with silicone spray if necessary
This way, you will achieve the best result for quiet sliding.
faabram37 schrieb:
Does anyone know specific models or versions of the PAX series where the sliding doors operate especially quietly? I recommend the PAX sliding doors with soft-close from IKEA. Standard models are usually noisier. Proper installation and regular cleaning of the tracks are also important.
