ᐅ Which Ikea Pax models are suitable for storing sports equipment?
Created on: 18 Apr 2015 09:23
plolu52
plolu52
18 Apr 2015 09:23
I am currently considering which Ikea PAX models would be best suited for storing my various sports equipment. I have gear for both indoor and outdoor sports, ranging from tennis rackets and helmets to larger fitness mats and shoes. It is also important to me how versatile the interior fittings of the wardrobes are, so that different items can be stored efficiently. Additionally, I would like to know which widths, heights, and depths are available, and if there are any specific add-ons such as drawers or pull-outs that work particularly well for sports gear. Has anyone had experience with specific PAX models that have proven reliable? Which configurations offer the most storage space for sports items, and how sturdy are they for heavier equipment?
FAZAR
18 Apr 2015 11:08
The question of which Ikea PAX model is suitable for sports equipment is complex. Generally, I would recommend the 50 cm (20 inches) wide frame, as it offers a good balance between storage space and flexibility. It can be perfectly combined with various inserts that are very practical for sports gear. For example: - Shelves should be made of metal to better support the weight of heavy helmets or bags and prevent sagging. - Drawers with grids or mesh inserts are excellent for smaller items like gloves or bands. - For longer items such as tennis rackets and yoga mats, a depth of 58 cm (23 inches) is advisable; this provides enough room without appearing oversized. Even more important is the internal organization: adjustable clothes rails can be used to hang straps or jackets. Full-extension drawers make it easier to pull out larger bags. Pay attention to stability: PAX is generally sturdy, but depending on the height, it can become unstable without wall anchoring when heavily loaded. Question: How much space do you exactly have in your room? This influences the choice between 201 and 236 cm (79 and 93 inches) in height. Also: Will the equipment change frequently, or are you looking for a more long-term solution? These details help with a precise recommendation.
Negutau
18 Apr 2015 11:42
I find the 75cm (30 inches) width better if you have a lot of stuff. Simply more space and greater flexibility. The 50cm (20 inches) ones are suited for smaller items, but not optimal for large equipment.
nausu
18 Apr 2015 14:15
For organizing sports equipment with Ikea PAX, I recommend a combination of several components: - Frame size: a depth of 50 cm (20 inches) and a height of 201 cm (79 inches) are sufficient for most sports items and can be used effectively even in small rooms. - Interior fittings: metal shelves instead of wood are more stable and durable, especially for heavy equipment. - Mesh drawers provide ventilation and prevent odors, which is advantageous for sports gear. - Pull-out shelves or drawers make it easier to access items stored inside the wardrobe. - Clothes rods are useful when storing textiles (e.g., jackets, tracksuits). - A sensible division into compartments by type of equipment saves time when searching. Regarding durability: PAX is sturdy as long as the maximum load of the shelves is not exceeded. Secure wall anchoring is important to prevent tipping hazards. The modular elements can be upgraded and adjusted flexibly in the long term. Without room measurements, the basic model with maximum height is recommended to make full use of the storage space.
mipau
19 Apr 2015 08:55
I would recommend the models that are 201 cm (79 inches) tall with a depth of 58 cm (23 inches). Larger depths are better for bulky items. Also, always choose metal shelves, as they are more durable.
PERON
19 Apr 2015 12:02
FAZAR schrieb:
Even more important is the interior organization: adjustable clothing rails can be used to hang belts or jackets.
Exactly! And I would add that for athletes who often deal with wet gear, ventilated modules with grilles or open drawers work really well. This way, everything stays fresh and the closet doesn’t become a musty trap. 😄
Also great are small boxes and baskets that you can place on the shelves. They’re perfect for storing equipment without everything getting scattered. And if you suddenly get new items, you can easily rearrange the compartments.
So my tip: 75 cm (30 inches) width + 58 cm (23 inches) depth + a flexible mix of metal shelves, open shelving, and drawers. That really makes working with sports gear enjoyable. 💪🏽
