ᐅ Which Ikea Pax models are best suited for small spaces?
Created on: 12 Mar 2022 18:43
pakenu
pakenu
12 Mar 2022 18:43
I am currently considering getting a wardrobe from the Ikea Pax series, but I’m facing the challenge that my room is very small. Therefore, my question is: Which Ikea Pax models are especially suitable for small rooms? I am interested in which dimensions work best, whether there are specific versions that appear less bulky but still offer plenty of storage space, and what design options you would recommend given the limited space. It would also be important for me to receive tips on optimizing the interior layout, especially how to use the available space efficiently without overwhelming the room. I would be very grateful for any experiences, recommendations, and also advice on common mistakes people often make with Pax wardrobes in small rooms.
taudi
12 Mar 2022 20:27
Good question with a lot of depth – here is a brief overview that should help you. For small rooms, I recommend models with a depth of 50 cm (20 inches) instead of the classic 60 cm (24 inches). These save space and appear less bulky. Here are a few points to consider when choosing:
- Width: narrower models, for example 50 or 75 cm (20 or 30 inches) wide, are better than large, wide cabinets.
- Height: the standard height of 236 cm (93 inches) works well, making use of space up to the ceiling. Small rooms generally benefit from using vertical storage.
- Doors: sliding doors save space, especially in tight rooms.
For the interior layout: flexible fittings with shelves, clothing rods at different levels, and drawers are very useful. This way, you can organize items well without losing overview.
Typical mistakes include cabinets that are too wide and dominate the room, or rigid interiors that don’t make optimal use of the available space.
Joe52
12 Mar 2022 22:54
I can easily understand how challenging it can be to choose the right PAX wardrobe for a small room, especially when you want not only a functional closet but also to create an airy and spacious feel.
taudi schrieb:
Typical mistakes include choosing wardrobes that are too wide and dominate the room, or having a rigid interior layout that doesn’t make the best use of the available space.
This is exactly what I experienced myself. At first, I had a wider PAX wardrobe measuring 100 cm (39 inches) wide and 60 cm (24 inches) deep, which felt really overwhelming in my small room. After switching to a model that is 50 cm (20 inches) deep and 75 cm (30 inches) wide with sliding doors, the space felt much larger, yet I didn’t lose any storage capacity. Playing with sliding doors can really make a big difference. It also helped me stay flexible with the interior setup, so I could rearrange the shelves later if my needs changed.
nonpra
13 Mar 2022 08:17
A depth of 50 cm (20 inches) is usually optimal for small spaces. Widths up to 75 cm (30 inches) are easy to handle. Sliding doors save space. Choose interior fittings flexibly to use the area efficiently.
giabau
13 Mar 2022 10:36
In addition to the helpful contributions so far, I would like to offer you a step-by-step recommendation on how to choose the PAX system optimally for small rooms:
- Check dimensions: First, measure your room precisely, especially the width and ceiling height.
- Use the 50 cm (20 inch) depth option available from Ikea – it makes a huge difference in tight spaces.
- Opt for narrow units with 50 or 75 cm (20 or 30 inch) width, as slim wardrobes fit better next to doors or desks.
- Prefer sliding doors: They do not require additional clearance for opening and provide more flexibility.
- Plan the interior: Take your time designing the shelves, hanging rails, and drawers.
A common mistake is to simply choose the largest PAX unit without considering the room’s spatial effect or adapting the interior to your specific needs. This makes all the difference, especially in small rooms.
Tip: Ikea offers a planner app that lets you virtually place the wardrobes in your room. It is worthwhile to use it to avoid buying mistakes.
sonplo
14 Mar 2022 09:03
Joe52 schrieb:
I initially had a wider PAX wardrobe measuring 100cm (39 inches) in width and 60cm (24 inches) in depth, which felt quite overwhelming in my small room. After switching to a model that is 50cm (20 inches) deep and 75cm (30 inches) wide with sliding doors, the room felt noticeably larger, yet I didn’t lose any storage space.
This perfectly illustrates the issue. I would add that it’s better to opt for several narrower wardrobes rather than one wide one. This offers more flexibility in arranging furniture and fits better with other pieces in the room. The 50cm (20 inches) depth option is truly a blessing for small spaces since it doesn’t restrict walking space as much.
Additionally, choosing lighter-colored fronts can visually enlarge the room.
