ᐅ Which Ikea Pax doors are best suited for people with allergies?
Created on: 29 Apr 2022 08:17
Len64Hello everyone, I am currently looking into Ikea PAX wardrobe systems, with a particular focus on allergy-friendly options. My main question is: Based on your experience or knowledge, which Ikea PAX doors are best suited for allergy sufferers – meaning those that bind as few allergens as possible, are easy to clean, and emit little dust or harmful substances? I am interested in the different materials and finishes of the doors, such as solid wood, plastic, mirror, or other coatings. Are there any specific recommendations or considerations to keep in mind when choosing? Thanks in advance!
DUVIN schrieb:
Solid wood collects dust and is harder to clean.DUVIN is definitely right! 🙂 I would add that for allergy sufferers, doors with a smooth surface are recommended. No indentations or grooves – because these catch stubborn pollen and dust particles. PAX doors in high gloss or painted finishes are often great for this, as you can simply wipe them clean with a damp cloth, leaving no chance for dust to settle!
Interesting discussion so far! I would like to go into more detail about the materials.
Solid wood, as already mentioned, is generally less suitable due to its porosity, as it can absorb dust particles and the surface is harder to keep hygienically clean. Additionally, untreated wood can potentially emit more VOCs (volatile organic compounds) if not sealed, which can sometimes be problematic for allergy sufferers.
For PAX, Ikea mainly offers doors made of laminated particleboard, painted MDF panels, and sometimes smooth plastic surfaces.
- Laminated fronts are affordable and can be easily cleaned with a mild damp cloth, but you should make sure the edges are well finished, as dust can accumulate in gaps otherwise.
- Painted MDF doors feature very smooth and sealed surfaces that attract little dust and are easy to clean. It is important that the paint is low in harmful substances, which Ikea usually states.
- Mirror doors are reflective and smooth, therefore easy to clean, but can be uncomfortable for people sensitive to touch, and there is a higher risk of accidents with children.
Do you have any experience with how the doors hold up after repeated cleaning? Does the paint chip or the laminate peel? This could be important for allergy sufferers who need to clean more often.
Hello Len64, I’m happy to help you find the best solution for allergy sufferers.
From my experience and reputable sources, I can only emphasize that a smooth, sealed surface is the most beneficial.
- Painted doors usually have a melamine or lacquer coating that acts as a barrier against dust, dirt, and allergens.
- Also consider how the doors are maintained in daily use: For allergy sufferers, regular dust removal with a damp cloth is important.
- Mirrors are hygienic but offer little therapeutic benefit for allergy sufferers since they do not have the filtering properties of a good surface.
An important question in this context: How severe are your allergic reactions to dust or house dust mites? Depending on that, the door construction and indoor climate factors could also play a role.
For additional information: IKEA PAX doors with a painted MDF surface offer an excellent combination of easy cleaning, low allergen retention, and high durability. The paint prevents allergens from penetrating and allows for regular, thorough cleaning without damage.
Furthermore, I recommend choosing the doors in combination with good-quality wardrobe interiors and breathable fabrics such as cotton. While plastic-coated doors are easy to maintain, they can sometimes have a slight chemical odor depending on the manufacturing process, which may be a concern for sensitive allergy sufferers.
