ᐅ Which Ikea wardrobe components are compatible with the PAX wardrobe system?
Created on: 15 Jul 2022 09:37
Lau39
Lau39
15 Jul 2022 09:37
I am currently planning to expand or modify my existing Ikea PAX wardrobe but am having trouble figuring out exactly which Ikea wardrobe components are compatible. Specifically, I am interested in which shelves, drawers, doors, and interior organization elements from the Ikea range fit into the PAX wardrobe without causing issues during assembly or everyday use.
My question: Which Ikea wardrobe parts actually fit in the PAX wardrobe? It would be great if someone could share their experience with different combinations of PAX components and other Ikea products or provide tips on what to watch out for when purchasing to ensure smooth integration.
Thanks in advance for your advice!
Deandre
15 Jul 2022 10:06
Hello Lau39,
Regarding your question: In general, all shelves, drawer fronts, and interior fittings specifically designed for PAX are, of course, compatible. This also includes inner drawers, pull-out trays, and clothes rails.
When it comes to cabinet parts from other series, caution is advised. Many parts have similar dimensions but are not always designed for the load capacity and mounting system used in PAX.
Lau39 schrieb:
Which Ikea cabinet parts actually fit in the PAX wardrobe?
The following assembly tips might help:
- Use only the appropriate screws and fasteners to avoid stability issues
- Doors from other series generally do not fit, as PAX doors have a unique hinge and track system
- For the interior, drawers from the METOD kitchen cabinets often work since similar dimensions are used, but always check if the rails and load capacity are compatible
If you plan to use door or drawer fronts from other series, I recommend checking the Ikea measurements and descriptions carefully in advance, as the PAX system is quite specific.
Hope this helps you for now!
draleo
16 Jul 2022 14:42
In addition to Deandre’s previous response, I would like to list some precise points to consider regarding compatible Ikea components within the PAX wardrobe system:
- Shelves: PAX typically uses 15mm (0.6 inch) thick boards with specific support rails; do not use other arbitrary boards.
- Drawer slides: PAX drawers employ a specialized ball-bearing slide system that differs from METOD or BESTÅ.
- Doors: PAX doors have unique mounting profiles and hinges that are not compatible with other series.
- Interior organization: PAX offers a modular system with hanging rails and baskets that are specifically designed for wardrobe depths of 35cm (14 inches) or 58cm (23 inches).
Deandre schrieb:
Doors from other series generally do not fit, as PAX doors have their own hinge and rail system
Therefore, it is advisable to use PAX components for any extensions to avoid frustration during assembly and use. Ikea itself recommends using only the corresponding products for PAX upgrades.
In summary: only parts explicitly listed as PAX-compatible should be used. For custom interior fittings, you can combine PAX internal elements rather than other Ikea furniture components.
This prevents errors and ensures proper fit.
theota
17 Jul 2022 08:29
It is interesting that there is such a strict focus on compatibility here. This makes me wonder whether Ikea’s product policy is actually pushing customers into a kind of monopoly.
draleo schrieb:
It is therefore advisable to use PAX components also for extensions to avoid frustration during assembly and use.
In my experience, shelves and hanging organizers from many series can indeed be combined if you improvise a bit and don’t insist on using the original fasteners. Completely rejecting the integration of other parts is, in my opinion, a misunderstanding of “compatibility.” Ikea produces standardized dimensions that often fit surprisingly well if you have some DIY skills.
Of course, there are functional differences, but the potential for mixing and matching is greater than many think. Ikea users should experiment more instead of strictly following the guidelines.
Lau39
18 Jul 2022 20:11
Thanks to everyone for the previous responses.
I see that the basic compatibility of PAX-specific components is very high, especially for shelves, drawers, and doors. However, I am interested in whether elements from other IKEA product ranges, such as BESTÅ or even the METOD kitchen series, can theoretically be fitted into the PAX framework without major modifications.
theota schrieb:
In my experience, shelves and hanging organizers from many series can definitely be combined with some improvisation
Could someone explain in more detail which parts they mean? I’m not thinking of complete doors, but rather interior fittings that can be used to improve organization.
Also, I wonder how the difference in depths of PAX units (35 cm (14 inches) vs. 58 cm (23 inches)) is handled when using components from other series. Are adjustments necessary?
I look forward to more advice, as I plan to upgrade my wardrobe functionally and don’t want to buy everything new.
