ᐅ Which adhesive is suitable for repairs on IKEA Besta units?
Created on: 17 Nov 2021 09:17
rontra
rontra
17 Nov 2021 09:17
I have a small issue with my IKEA Besta shelf, where one of the drawer joints has come loose. Since I don’t want to replace the entire piece, I’m looking for a suitable adhesive that works well for repairs on the MDF and particle board surfaces of this furniture. Besides strong bonding, it’s important to me that the glue is not too visible after drying and ideally remains a bit flexible to withstand stress.
Has anyone had experience with which adhesive is best suited for this? I’ve read quite a bit about wood glue, construction adhesive, and epoxy resin, but I’m unsure what the optimal solution is in this case. In particular, I’m interested in:
- Which adhesives bond well to coated particle board or MDF?
- How can I ensure the long-term durability of the joint?
- Are there adhesives that can be applied precisely without leaving unsightly stains?
I look forward to your recommendations and tips. Thanks in advance!
Daledra
17 Nov 2021 09:42
For IKEA Besta, I would recommend a good wood glue, preferably one specifically designed for glued surfaces in furniture making. It adheres well to chipboard and becomes almost invisible after drying.
Epoxy resin is strong but often too thick and difficult to apply precisely, especially for hidden areas. If the joint is under significant stress, construction adhesive could be an alternative, but it is often visible.
minan
18 Nov 2021 14:03
Daledra schrieb:
For IKEA Besta, I would recommend using a good wood glue, preferably one specifically designed for laminated surfaces in furniture construction.
I agree with that, but would like to go into more detail.
IKEA Besta furniture often consists of particleboard or MDF panels with a coated surface, usually a melamine resin layer or similar. This coating can cause issues during bonding since it reacts differently to adhesives and sometimes has low absorbency.
- A classic white glue (PVA glue) works well if the surfaces to be joined are untreated or slightly roughened. Adhesion is weaker on smooth melamine surfaces.
- Two-component epoxy resin provides a very strong bond and adheres to many substrates but is difficult to work with and better suited for visible areas or larger surfaces. Additionally, curing time is significantly longer, and any excess glue must be removed immediately.
- Construction adhesive (e.g., polyurethane-based) has the advantage of remaining flexible and can compensate for unevenness. However, it is often visible and difficult to remove afterwards.
Therefore, if the bonding surface is coated, I recommend gently roughening it first (using fine sandpaper) to improve adhesion. Then use a good wood glue that can penetrate slightly. If the glued joint will be under high stress, small screws or clamps can also be used for additional fixation.
One more question: Is this a drawer that simply needs to be reassembled, or is it a break in a load-bearing part? That would influence the choice of adhesive.
lalutau
19 Nov 2021 07:56
rontra schrieb:
I have read quite a bit about wood glue, construction adhesive, and epoxy resin, but I’m unsure which is the best solution in this case.
For clarification and a more straightforward approach:
- Adhesives for furniture made of particleboard or MDF should ideally be designed for coated surfaces or provide sufficient adhesion on smooth finishes.
- PVA glue (white glue) usually does not bond well to melamine coatings but can be improved by lightly sanding the surface beforehand.
- Polyurethane-based construction adhesive bonds well and remains flexible, but it is not invisible and can be difficult to apply precisely.
- Epoxy resin is strong but unnecessarily complicated for simple drawer repairs and requires accurate mixing.
My recommendation:
First, roughen the gluing surfaces, then use a high-quality wood glue. If the load is significant or the joint is load-bearing, additionally reinforce the connection mechanically (screws, brackets).
Careful preparation and clamping of the parts until fully dry are crucial for long-lasting durability.
