ᐅ Which DIY projects are worth doing with Ikea Hemnes beds?
Created on: 13 Sep 2022 11:23
Benmathias
Benmathias
13 Sep 2022 11:23
Hello everyone, I am considering using an Ikea Hemnes bed for a DIY project because I really appreciate its sturdy construction and timeless design. I am particularly interested in which types of DIY projects are truly worthwhile when it comes to redesigning or functionally expanding a Hemnes bed. I don’t just mean simple repainting or the classic upcycling approach, but well-thought-out modifications, extensions, or clever additional features that significantly enhance both utility and style. Does anyone have experience or ideas on projects that work especially well with the Hemnes bed? And what should be kept in mind, especially regarding stability and material compatibility?
WARREN
13 Sep 2022 11:45
The best storage solutions are under the Hemnes bed. Simply adjust or build drawers yourself; they fit perfectly. Important: Secure the rails well, otherwise they will squeak. Alternatively, upgrading the headboard with lighting always adds appeal.
Lamar
13 Sep 2022 13:17
What I criticize about all DIY projects with Hemnes is this: The wooden structure is stable, but often too <i>conservative</i> for elaborate designs. If you’re looking for something truly innovative, it’s better to extend or modify with metal. So why use Hemnes at all? I think many miss out on potential by only focusing on paint or simple screws.
Joe52
13 Sep 2022 14:03
I understand Lamar's point, but I would like to add that many people choose the Hemnes precisely because of its simplicity and classic look. As someone with limited DIY skills, I was able to turn it into a daybed using simple instructions. For me, it was a small challenge, but with a bit of patience, I managed it. I also appreciate when something is handmade, as it strengthens the connection to the furniture.
Guyju
13 Sep 2022 18:29
If you want to use the Hemnes bed as a base for DIY projects, you should consider the following steps: - Check the existing screws and connections, as they can become tight over time - Sand the wood surfaces before applying new paint or stain; otherwise, the finish won’t adhere properly - For built-ins like drawers or shelves under the bed, I recommend using sturdy metal slides and reinforcing the base with double support, since the original bottom panel has limited weight capacity. Also, converting it into a loft bed with an integrated reading nook works well and is very popular for small spaces. In my opinion, the Hemnes series provides a solid foundation as long as you respect the material limitations.
Nakar33
14 Sep 2022 09:12
Very interesting topic. I would like to get a bit more technical because the Hemnes beds are made of solid pine wood, which has both advantages and disadvantages: On one hand, it provides good stability, but on the other, the wood tends to expand and contract due to moisture. This should be taken into account in DIY projects, especially when adding components like shelves or drawers to the construction. Therefore, it is important to have a good surface finish and to maintain some clearance from the floor panel to prevent moisture absorption. Ideally, the bed frames should be reinforced with additional cross beams if you plan to build, for example, a loft bed or a bunk bed. In this context, I also wonder whether the original poster is precisely planning whether the DIY project will change the mattress support or just add extra furniture?
