ᐅ Which DIY projects are especially suitable for IKEA Hemnes furniture?
Created on: 30 May 2022 08:37
Gau_nu0Hello everyone, I’m currently exploring DIY furniture building and have come across the IKEA Hemnes range. I’m especially interested in which DIY projects, based on your experience, work particularly well with the versatile Hemnes pieces. I’m not only thinking about simple enhancements like painting or changing handles but also creative redesigns, combining them with other materials, or functional extensions. Perhaps you have examples from your own experience or recommendations for projects that can be done with minimal tools and basic DIY skills, yet still provide significant added value in everyday life? I’m looking forward to your tips and ideas!
That’s a great question, as the Hemnes range really offers many possibilities. In general, Hemnes dressers and cabinets are perfect as a base for upcycling projects. I would especially recommend the following DIY ideas:
- Convert dressers into bathroom vanities by cutting out the back panel and adding a countertop with a sink.
- Enhance shelves with carefully integrated LED strips to create a pleasant atmosphere.
- Replace doors with glass or fabric inserts to achieve semi-transparent fronts.
It’s important to carefully check the material before starting the project, as it’s usually MDF, which can be worked differently depending on the type. For simple repainting and replacing handles, I also recommend sanding the surface beforehand to improve adhesion. Which Hemnes models do you have available?
Deandre schrieb:
Which Hemnes models do you specifically have available? Good question! I currently have a Hemnes dresser with 8 drawers and a Hemnes sideboard in white. Should I take these into account when evaluating the projects? I’m definitely open to expansion ideas that combine or functionally connect multiple pieces of furniture. This is probably relevant for stability or the choice of materials.
First, it is important to manage expectations when undertaking DIY projects with Hemnes furniture. IKEA furniture is generally not designed for extensive modifications, as the MDF and particleboard materials often have limitations.
Although this idea sounds appealing, the long-term water resistance should be carefully evaluated to avoid moisture-related damage.
I would recommend focusing projects more on aesthetic and functional adjustments rather than structurally or technically complex alterations. For example, you could work with paint, handles, and simple additional components like top-mounted shelves.
Deandre schrieb:
Repurposing dressers as bathroom vanities by cutting out the back panel and adding a countertop with a sink.
Here is a small tutorial for a DIY project using the Hemnes 8-drawer dresser that I completed myself:
- Goal: Create a wooden work surface on top of the dresser for placing items, while also adding a visual highlight with a wall panel behind the dresser.
- Preparation: Clean the dresser, lightly sand the surface (grit 120), and paint it with matte paint.
- Worktop: I had an 18 mm (0.7 inch) thick solid wood board cut to size, which is placed on the dresser (not screwed down) so that the drawers can still be accessed if needed.
- Wall panel: Used leftover wooden strips, screwed them vertically to the wall, and painted them in a color matching the dresser.
Tip: When choosing the wood board, it’s best to select a type that doesn’t warp easily, such as beech or oak.
With little effort, the dresser looks much more high-quality and multifunctional. These kinds of upgrades are great for beginners and avoid major technical modifications.
