ᐅ Which DIY projects can be done using IKEA Hemnes furniture?
Created on: 10 Apr 2020 09:37
ELSABAR
ELSABAR
10 Apr 2020 09:37
I’m currently diving into DIY projects related to furniture and have come across the IKEA Hemnes series. Since these pieces are often used as a base for customizations due to their classic look and sturdy construction, I’m curious:
What specific DIY projects can be done with IKEA Hemnes furniture? I’m not just talking about simple changes like painting or new handles, but also functional modifications, upcycling ideas, or even complex rebuilds that transform Hemnes pieces into completely new furniture.
Maybe some of you have experience or know of good inspirations that go beyond the usual tweaks while remaining practical and durable. Are there any special considerations regarding material quality or assembly that should be kept in mind for such projects?
Looking forward to your ideas and experiences!
GALEO4
10 Apr 2020 10:14
Interesting question! I think Hemnes furniture is solidly built, but unfortunately not exactly the height of creativity—at least when it comes to unusual DIY projects. Most projects end up being just "I’ll paint it differently" or "add shelf extensions."
You could almost say that the Hemnes series from IKEA is a fair compromise between modularity and a uniform look, but it offers too little to truly innovate with.
It would be interesting to know if anyone here has ever transformed Hemnes into something completely different, like a sofa or a stylish kitchen island... Personally, I doubt that, but I’m happy to be proven wrong.
RETRAVIS
10 Apr 2020 10:53
Hemnes furniture is made of solid pine wood, which generally makes it well suited for a variety of DIY projects. Its durability allows for modifying and functionally expanding the furniture.
Specific ideas I would consider:
- Converting dressers into TV media units by adding cable openings and extra shelves
- Transforming cabinets into workstations by installing drawer inserts or desktop surfaces
- Upcycling into a bench by reinforcing and upholstering the top
I would advise against more complex alterations, such as converting into beds or sofas, without the necessary expertise, as the construction and joint connections need to be adapted, which could compromise stability.
pinpa
10 Apr 2020 12:07
I really like the Hemnes series for relatively straightforward yet visually effective DIY projects. For example, I once made a simple bench from a Hemnes TV lowboard: using the base frame as a foundation, then adding a padded seat on top – it fits perfectly in the hallway and looks great.
What I find brilliant is that Hemnes furniture isn't just easy to paint or varnish, but with a bit of creativity, you can often create new functions without it becoming expensive.
Sure, making a sofa from Hemnes would be difficult, but a small home bar, a bedside table with charging functionality, or even a bookshelf with hidden storage? Totally doable and completely in the DIY spirit!
BAUEVA
10 Apr 2020 13:21
I find the question of material quality particularly interesting with regard to durability after modifications.
RETRAVIS schrieb:
Hemnes furniture is made from solid pine wood, which generally makes it well-suited for a variety of DIY projects.
While solid wood is durable, it is important to remember that IKEA often uses glued components, whose load-bearing capacity can be compromised by extensive alterations.
I would strongly recommend that anyone planning complex modifications to Hemnes furniture carefully assess whether the structural integrity is maintained—especially when changes affect load-bearing elements.
This is particularly relevant when converting Hemnes dressers into other types of furniture, where the original construction may no longer be clearly recognizable.
Fredlo
10 Apr 2020 14:45
I am a big fan of DIY projects with Hemnes! Especially because the furniture is relatively affordable yet solid, they offer great possibilities.
Last year, I converted a Hemnes chest of drawers into a stylish workbench cart: added casters underneath, installed an extra shelf, and placed a sturdy work surface on top. It worked really well and makes DIY projects much more enjoyable!
My recommendation: Don’t just make cosmetic changes, but also improve the functionality to suit your daily needs – that’s how truly unique pieces of furniture are created!
