ᐅ What child safety devices can I install on Ikea Besta cabinets?
Created on: 17 Oct 2016 08:37
Glafo
Glafo
17 Oct 2016 08:37
Hello everyone, I am looking for recommendations for child safety devices that I can install on my Ikea Besta cabinets. It is important to me that the locks reliably prevent my little ones from opening the doors or drawers and potentially hurting themselves or causing damage. I am interested in both mechanical and magnetic solutions that can be easily installed without damaging the furniture or requiring complicated modifications. Does anyone have practical experience with such safety systems for Besta shelves or can name specific products that work well and are easy enough for children to use safely? Tips on the best attachment methods and installation would also be appreciated. Thanks in advance!
tetan
17 Oct 2016 08:45
I recommend looking for magnetic child safety locks that can be attached to the inside of the door. They are discreet and work well with young children. Alternatively, there are simple clamp or latch systems that can be clamped on. It’s best to choose ones that can be installed without drilling.
parbau
17 Oct 2016 09:13
Hey, I had the same question once 😂 We installed magnetic lock flaps here – those magnetic locks. Our little ones really respect these invisible little "guardians." 😄 Advantage: the door stays intact, and so do the nerves. Easy to install, no visible barriers – basically a home protection solution for little ones! 💪
TEBILO
17 Oct 2016 11:24
To select the appropriate child safety devices for Ikea Besta cabinets, you first need to consider the different types of cabinet fronts and opening mechanisms. Most Besta units feature doors with soft-close hinges and optional drawers. For mechanical locks, latch or sliding bolts are suitable; these are attached to the inside of the doors and prevent opening with a simple closure. It is important that these fittings do not damage the hinges or wood, especially if the landlord objects. Magnetic child safety locks work with an internal magnetic bolt and a key that is required to open from the outside. They are very effective because small children cannot operate the key. Installation is usually done with screws or adhesive pads, with screws providing a more secure attachment. Alternatively, flexible strap locks that wrap around the cabinet doors offer a simple but less aesthetically pleasing solution. In general, it is advisable to check the load-bearing capacity of the doors before installation to avoid damage from additional devices. Would you like me to provide specific product names or sources?
Glafo
17 Oct 2016 12:02
TEBILO schrieb:
To choose the right child safety devices for Ikea Besta cabinets, you first need to consider the different types of cabinet fronts and opening mechanisms.
Thank you, that’s exactly the point. My Besta shelves have soft-close wooden doors—not something very thin. I want the devices to be as unobtrusive as possible since the furniture is in the living room.
parbau schrieb:
We installed magnetic locks—those magnetic child safety locks.
Cool, how reliable are they in everyday use? Can you say if kids eventually figure out how to bypass them? I’m not so keen on strap locks because of how they look. I’m also looking into installation options that don’t require drilling into the wood, if that’s possible.
janeo
17 Oct 2016 15:37
I’m wondering: Are magnetic locks really the best choice for built-in cabinets if you want a clean look and easy installation without damage? Many of these systems require screws and leave visible marks. Adhesive pads might reduce adhesion on smooth surfaces like lacquer or veneered finishes. It’s also worth considering that some plastic clamps can become brittle over time. Does anyone have comparisons between different solutions, especially regarding durability and long-term child safety? Mechanical latches are secure but could be inconvenient for daily use.
