ᐅ Which care products are especially recommended for Ikea Hemnes furniture?
Created on: 30 Mar 2022 08:43
Kogla
Kogla
30 Mar 2022 08:43
Hello everyone, some time ago I purchased several pieces of furniture from the Ikea Hemnes series, mainly dressers and nightstands made of lacquered pine wood. Since I want to keep the furniture in good condition for as long as possible, I’m wondering: which care products are especially recommended for Ikea Hemnes? I’m looking for specific products that both protect the surface and enhance the appearance without damaging the lacquer or the wood. Maybe there are also special tips or methods for application? I look forward to your recommendations and experiences.
minan
30 Mar 2022 10:17
Hello Kogla, basically, for Ikea Hemnes furniture, which is mostly made of lacquered pine wood, it is important to use gentle cleaning products without harsh solvents.
The best approach is to use a damp microfiber cloth with a mild soap solution, such as a few drops of neutral dish soap in water. This way, you can remove dust and dirt without aggressive chemicals.
For long-lasting care, special furniture oils or waxes that also provide water resistance are rather unsuitable because they can dissolve or damage the lacquer. Instead, I recommend high-quality water-based furniture polish with UV protection, which nourishes the finish without harming it.
Two additional tips:
- Avoid products containing silicones, as they can degrade the surface over time.
- Always apply care products thinly and evenly, and let the furniture dry thoroughly.
The type of surface care you use also depends on whether the furniture is directly exposed to stress like heat, moisture, or abrasion. How do you use your furniture?
Rensan3
30 Mar 2022 11:08
Use a mild detergent diluted in water for cleaning, followed by a soft, slightly damp cloth. For protection, a high-quality wax-based furniture polish is suitable, but always use it sparingly.
gadalu
31 Mar 2022 09:32
minan schrieb:
The best approach is to use a damp microfiber cloth and a mild soap solution, such as a few drops of a neutral dish detergent in water. This way, you can remove dust and dirt without using harsh chemicals.
This is a reliable basic rule. Additionally, I recommend using water-based furniture polishes that do not contain silicone oils, as these can damage the finish over time.
Furthermore, you should keep in mind that Ikea Hemnes furniture is typically sealed with a clear acrylic lacquer. For heavier dirt or stains, gentle cleaning with 70% isopropyl alcohol is also possible, but always test first in an inconspicuous area.
In summary: gentle cleaning, small amounts of silicone-free furniture polish, and no oil-based care products.
GALEO4
1 Apr 2022 07:59
I find the whole discussion about care products to be somewhat exaggerated. Ikea Hemnes furniture is basically solid wood with a lacquer finish – not high-end antiques.
minan schrieb:
For long-lasting care, special furniture oils or waxes that also provide water resistance are rather unsuitable, as they can dissolve or damage the lacquer.
I see it differently: Often, regular dusting and maybe the occasional light polish is enough – nothing special.
Why make it complicated? Everyday furniture should be able to handle everyday care and shouldn’t require treatment like it’s in a hygiene clinic. In the end, it’s about functionality, not maintaining a perfect showroom piece.
laureo
1 Apr 2022 12:21
In my experience, it is indeed best to keep the care of Ikea Hemnes furniture as simple as possible.
Regular wiping with a slightly damp cloth is usually sufficient to keep the furniture looking attractive. It is advisable to avoid using harsh cleaners to prevent damaging the finish. If you wish, you can apply a water-based furniture polish once every three months to help maintain the shine.
It is also important not to use abrasive sponges or scratching materials, as these can cause micro-scratches on the finish.
