ᐅ Which Billy shelves are designed to support heavy loads?
Created on: 5 Jan 2021 09:12
Ixne57
Ixne57
5 Jan 2021 09:12
I am currently planning the layout for my storage area and intend to use IKEA Billy bookcases for this. Since I will be storing relatively heavy items there—mainly some technically heavy equipment and binders that weigh well over 20 kg (44 lbs) per shelf—I have the following question:
Which Billy bookcases are specifically designed for high load capacities, meaning which versions or modifications can support a lot of weight without losing stability?
If you have any experience with reinforcements or alternative shelves, I would also greatly appreciate hearing about that.
Thanks in advance!
NoValentin
5 Jan 2021 09:45
Basically, the standard Billy shelves can support up to about 30 kg (66 lbs) per shelf, but for heavier loads, I recommend the metal shelves from the IKEA range. They can withstand significantly more weight.
naujon
5 Jan 2021 10:03
Hello Ixne57,
I would like to provide a brief overview:
1. Standard Billy shelves: Load capacity per shelf is approximately 13–30 kg (29–66 lbs), depending on the type of shelf panel.
2. Metal shelves: These are especially sturdy and can support up to about 50 kg (110 lbs).
3. Additional reinforcements: Using brackets or extra supports can increase the load capacity.
Tip: Also pay attention to the wall mounting, as the stability of the entire shelving system often depends on it. Without secure wall anchors, it may tip or break under heavy load.
If you need more details, feel free to ask!
Ixne57
5 Jan 2021 10:31
NoValentin schrieb:
Metal shelves from the IKEA range are much more durable.
That sounds interesting. Can these metal shelves be ordered individually, or do you have to buy the entire shelving system with these shelves? What are the approximate costs?
Also: Are there differences depending on the Billy variant? (Width, height, depth) I need 80 cm (31.5 inches) width, possibly 40 cm (15.7 inches) depth.
JAPLO
5 Jan 2021 11:05
IKEA metal shelves are usually sold separately and fit depending on the model and dimensions.
Make sure to choose the correct size; the thickness also affects stability and load capacity.
For a width of 80 cm (31.5 inches), there are suitable metal shelves that can support a significantly higher load than standard wooden shelves.
The shelf height can also influence stability – tall units should always be secured to the wall.
It is worth carefully checking the product information on the IKEA website and asking in store if necessary.
GAGRAHAM
5 Jan 2021 11:29
That’s brilliant! 🙂
I’ve been using the 80cm (31.5 inches) Billy shelves with metal shelves for years to store my heavy photo equipment and professional filing binders.
With wall mounting and the metal shelves, I can easily support 40 kg (88 lbs) per level. Super stable and very practical!
By the way, a tip: If you want to customize the shelves with color, they can be painted well – the wooden boards handle it great, especially if they’ve been reinforced.
