I am planning to use several IKEA Billy bookcases in my hobby room to store quite heavy items such as several heavy binders and some tools. However, I am unsure which versions of the Billy bookcases are best suited for this purpose.
I understand that there are different models of the Billy, for example with classic wood-based panels, metal reinforcements, or different types of shelves. My specific question is: which Billy bookcases or features are best for safely supporting heavy loads over time without the shelves sagging or the unit becoming unstable?
I would appreciate any experiences, practical advice, and possibly tips on upgrades or alternative products within the Billy range, as the bookcase needs to fit well aesthetically in the room but also be secure and load-bearing.
Thanks in advance for your support!
Hello Achim50,
your question about the load-bearing capacity of the BILLY shelves is very relevant, especially when dealing with heavy loads. Generally, the standard shelves of the BILLY unit are designed to support around 15 kg per shelf, which is quite sufficient for books or binders but tends to reach its limits with particularly heavy items.
For higher loads, it is recommended to use the metal shelves offered by IKEA for the BILLY system. These are more stable and can usually carry significantly more weight. Adding extra metal brackets to reinforce the shelves can also be a good idea.
Additionally, make sure to place the unit on a level surface and secure it to the wall to improve stability and prevent tipping.
If the weights significantly exceed the standard load capacity, it might also be worth considering alternatives beyond the BILLY system, such as metal shelving units.
I agree with lyndon. The standard wooden shelves from BILLY are relatively thin and tend to bend under heavy loads. If you want the BILLY look, consider using the metal shelves instead.
Additionally, there is a new "BILLY for storage" model that IKEA is testing in certain markets, but it is not available everywhere.
Important: Regardless of the shelf type, never exceed the maximum load capacity per shelf and consider distributing the weight across multiple shelves or units.
flo-Theres25 Sep 2024 11:29In addition to metal shelves, the "BILLY with insert" version can also be relevant – as the shelves are sometimes thicker and can therefore support weight better. If you want to store heavy tools, it might also make sense to distribute the weight as evenly as possible to avoid localized overloading.
Another tip: Additional braces at the bottom or a narrow back panel provide greater stability for heavy loads.
To answer the question precisely: Standard BILLY shelves are made of particleboard with a melamine coating. Each shelf can support a maximum of about 15 kg (33 lbs), as mentioned earlier.
In contrast, metal shelves have a significantly higher load capacity, with loads of up to 30 kg (66 lbs) per shelf being more realistic.
Additionally, BILLY offers frame constructions with metal supports that provide greater long-term stability.
Recommendation: Use only metal shelves, reinforce the shelf with metal brackets if necessary, and always secure the unit to the wall.
For significantly heavier loads, other types of shelving should be chosen, as BILLY was originally designed for light to medium loads.
