I have several Billy shelves from IKEA at home that I would like to make childproof and stable at the same time. Since we have a small, lively child, it is especially important to me that the shelves cannot tip over and that all corners and edges are secured to prevent the child from getting hurt.
I have read that they should be attached to the wall, but how exactly is the best way to do this if I have textured wallpaper (such as "Raufasertapete") and prefer not to damage the wall? I also wonder if there are special protective devices for the shelf corners and whether these protective measures could affect the stability.
Does anyone have experience with making Billy shelves safe and stable for children? What tips and materials would you recommend to prevent any wobbling and keep the child protected?
Thank you very much for your answers!
Hello Fra68,
I completely understand your concerns. The best solution is definitely to securely attach the shelves to the wall to prevent tipping. For textured wallpaper, I recommend using anchors that are specifically suited to the wall material—avoid anchors that are too large or coarse to prevent damage to the wallpaper and plaster.
For corners, there are special corner protection caps made of soft plastic or foam that can be easily fixed with strong double-sided tape. These are easy to remove, cause no damage, and reliably protect children. It is important that the shelves are mounted perfectly vertically to enhance safety.
Would you like to share your child’s age and the location of the shelves? That way, I can tailor the advice more precisely.
farna7 schrieb:
Would you maybe specify how old your child is and where the shelves are located? Then I can tailor the recommendations better.The child is two and a half years old and very curious. The shelves are in the living room and the hallway. Especially in the living room, I expect the child to climb on the edges more often. Therefore, the corners need to be protected, but stability is extremely important there as well. In the hallway, there is only a narrower Billy-style shelf that seems a bit less stable.
For wall mounting on textured wallpaper and common interior walls, I recommend universal wall plugs combined with pan head screws that fit the supplied angle brackets. This connection method is both practical and secure against tipping.
For added stability, the back panel of the shelves can be reinforced, for example, with a thin plywood sheet, which improves diagonal rigidity. Many users underestimate the effect of the back panel on the overall stiffness.
For child safety, the corners can be protected with standard corner guards or foam corner protectors. It is important that the protection does not interfere with the fixings or negatively affect the stability of the shelving unit.
Tool-free retrofitting by gluing is common, but you should use strong, low-emission adhesives or self-adhesive protective strips.
Hey Fra68,
with little rascals, I can only say: never underestimate how creative they get when climbing on furniture! 🙂
We’ve found these small, transparent silicone bumpers useful as corner protectors – they are barely visible and very soft. I secure the shelves to the wall with an IKEA mounting kit; honestly, it’s better than having a little climber knock the entire shelf over.
A handy tip: attach a strip along the bottom of the shelf to prevent the frame from bending and reduce the risk of tipping.
Good luck, you’ve got this! ;-)
