I have several Billy shelves from IKEA at home that I would like to make childproof and stable at the same time. Since we have a small, lively child, it is especially important to me that the shelves cannot tip over and that all corners and edges are secured to prevent the child from getting hurt.
I have read that they should be attached to the wall, but how exactly is the best way to do this if I have textured wallpaper (such as "Raufasertapete") and prefer not to damage the wall? I also wonder if there are special protective devices for the shelf corners and whether these protective measures could affect the stability.
Does anyone have experience with making Billy shelves safe and stable for children? What tips and materials would you recommend to prevent any wobbling and keep the child protected?
Thank you very much for your answers!
The question of combining safety (child protection) and stability with Billy shelves is more complex than it might seem at first glance.
First, the structural integrity of the individual shelf should be checked. Smaller Billy units without a central support do have a certain risk of tipping, especially when loaded or climbed on. It is advisable to secure the unit not only at the back but also to fix it to the floor or use anti-slip pads – this reduces vibrations and prevents slipping.
Wall fixation is essential: The supplied bracket should always be anchored to the wall with a suitable wall plug. If you have textured wallpaper, the substrate still needs to be stable (e.g., concrete or load-bearing plaster); special consideration is required for drywall (e.g., cavity anchors with expanders). Alternatively, heavy-duty anchors can be used.
For the corners, I recommend high-quality corner protectors made specifically for furniture, made of flexible, impact-absorbing plastic. These should be glued over a large area and firmly attached to prevent them from falling off. It is also advisable to apply these protective measures before the final assembly to avoid any installation issues.
One question for you: Do you plan to load the shelves with heavy items, or will they mainly hold lighter objects such as books or toys? This can influence whether you need additional reinforcements.
FAZAR schrieb:
Are you planning to load the shelves with heavy items, or will they mainly hold lighter things like books or toys?The shelves in the living room are mostly filled with children’s books, games, and a few decorative items, so a moderate load. In the hallway, shoes are placed on the Billy, which is somewhat heavier. That’s why the wobbling there concerns me a bit.
Thank you for the advice regarding the wall substrate – in a southern German apartment, walls are usually concrete, which should be stable enough. I will take a look at corner protectors! Are there any recommended products, perhaps with material information? I would prefer low-emission and as safe as possible materials.
RETRAVIS schrieb:
Additionally, reinforce the back panel of the shelves, for example with a thin plywood sheet that improves diagonal stability.That sounds interesting. What is the best way to attach such a plywood sheet without significantly altering the appearance of the Billy shelves? Is it sufficient to remove the back panel and screw or glue the sheet behind it? Are there any recommendations regarding the material thickness? I want to keep the shelves as original as possible while making them more stable.
