ᐅ How can I adapt Billy shelves to different room sizes?
Created on: 10 Sep 2019 18:07
flogau0
flogau0
10 Sep 2019 18:07
Hello everyone, I have a specific question regarding the adaptation of Billy shelves to different room sizes. I have often noticed that the standard dimensions of Billy shelves don’t always fit well in every room, especially in very narrow corridors or rooms with very high ceilings.
Specifically, I’m interested in what options are available to modify or configure Billy shelves so that they can be optimally integrated into small, medium, or very large rooms without compromising storage capacity or appearance.
Are there, for example, special adjustments for the width, depth, or height? Can additional components help ensure the best use of space?
I look forward to your experiences and tips!
COLEBAR
10 Sep 2019 18:12
In general, the different depths of the Billy shelves (28cm (11 inches) or 37cm (15 inches)) help to adapt to various room sizes. For small rooms, I recommend the narrow versions.
Additionally, extensions such as a top piece or corner connector are useful for flexibly adjusting heights or widths.
Laukau5
10 Sep 2019 18:25
Hello flogau0, to answer your question in more detail: Billy shelves are basically modular, which makes them adaptable. They are produced in heights of 106 cm, 202 cm, and 237 cm (about 42 inches, 79 inches, and 93 inches) and in widths of 40 cm, 80 cm, or 60 cm (for the narrower model) (about 16 inches, 31 inches, or 24 inches).
For very narrow spaces, I often use the 40 cm (16 inches) Billy, especially when the hallway width is limited. You can also better organize storage space by adding extra shelves or adjustable shelves with variable heights.
If the ceiling height is higher, the shelf can be extended with additional top modules or custom-built covers, so no unused gaps remain.
Another tip is to use corner solutions with suitable corner shelves, if the room allows.
I’m curious: How high are your rooms, and what is the width of the narrowest spot where the unit needs to fit? That way, I can offer more targeted advice.
flogau0
10 Sep 2019 18:38
Thanks in advance for the explanations! The ceiling height in my case is just over 250 cm (98 inches), and the narrowest spot in the room is only 85 cm (33 inches) wide.
I was also considering a depth of 37 cm (15 inches), but for the space in this narrow area, the shelf seems too deep.
Is there a way to customize the shelf depth, or would it be better to use several narrower and shallower shelves instead?
laureo
10 Sep 2019 18:47
With a ceiling height of 250 cm (98 inches), the standard height of the Billy bookshelves (up to 237 cm (93 inches)) is actually not quite enough, as there will be a larger gap to the ceiling.
My suggestion: use the tall 202 cm (79 inches) bookshelf and add a top section. This keeps the look harmonious and allows you to make good use of the height.
For your narrow passageway of 85 cm (33 inches), a 40 cm (16 inches) bookshelf is practical. For more stability, you can attach light wall fastenings behind the shelves to prevent wobbling.
Cutting the shelf depth yourself is problematic because the side panels are thin and could deform.
COLEBAR
10 Sep 2019 19:03
flogau0 schrieb:
Is there a way to shorten the shelf depth individually?
Shortening is not recommended. It’s better to use more narrow units instead. Shelf boards can sometimes be adjusted with custom cuts by a carpenter.
