ᐅ How can I make Billy shelves both child-safe and stable?
Created on: 29 Aug 2015 08:12
Fra68
I have several Billy shelves from IKEA at home that I would like to make childproof and stable at the same time. Since we have a small, lively child, it is especially important to me that the shelves cannot tip over and that all corners and edges are secured to prevent the child from getting hurt.
I have read that they should be attached to the wall, but how exactly is the best way to do this if I have textured wallpaper (such as "Raufasertapete") and prefer not to damage the wall? I also wonder if there are special protective devices for the shelf corners and whether these protective measures could affect the stability.
Does anyone have experience with making Billy shelves safe and stable for children? What tips and materials would you recommend to prevent any wobbling and keep the child protected?
Thank you very much for your answers!
FAZAR
30 Aug 2015 09:38
Fra68 schrieb:
How can I best attach a plywood board without significantly altering the appearance of the Billy shelves?
The back panel of the Billy shelves is usually a thin hardboard panel. It can be carefully removed by loosening the nails or staples from the back. Then, a thinner plywood sheet, for example 3–4 mm (1/8–3/16 inches) thick, can be cut to size and used instead of the original back panel.
To fix it in place, small screws on the sides are recommended, or alternatively wood glue on the shelf edges. Screws provide a more secure hold but will require careful filling and painting afterward if they are visible.
This modification significantly improves lateral stiffness and also dampens any creaking noise from wobbling. Make sure the back panel sits flat and flush. Many users recommend birch plywood, as it is stable, durable, and visually unobtrusive.
If you want to keep the original external appearance, the new back panel can be recessed inward so the original back remains visible on the outside, while the shelf frame is reinforced from the inside. However, this is more complex and usually only recommended for those experienced in furniture making.
leomo
30 Aug 2015 11:11
Plywood panels are a safe choice – and you can even get a bit creative with them: just add some color, and they become a design feature. 🙂
As for corner protectors: if you like adhesive protection, I recommend these felt corners. They look nice, are soft, and hold surprisingly well. Especially in the living room, they might be more stylish than brightly colored plastic corners 😉
Just don’t forget to secure them firmly to the wall! 👍
Fra68
1 Sep 2015 07:42
Thanks to everyone for the numerous tips!
I will first use the original wall mounting materials and choose the plugs suitable for the wall thickness. For the corners, I have now ordered EVA foam profiles, which sounds great.
I plan to try reinforcing the back panel with plywood early next week, once the measurements are taken— I think 3 mm (0.12 inches) thickness should be sufficient.
Regarding the weight: I will especially try to store the heaviest items as low as possible in the hallway.
If I gain any further experience, I will gladly report back here. Have a great day, everyone 🙂
Z
zartra
2 Sep 2015 08:03
Wall mounting with appropriate anchors + corner protection made of EVA + weight preferably at the bottom = a very good basis for child-safe and stable Billy shelves. Good luck.
