ᐅ How can I securely install BILLY shelves in rental apartments without using wall anchors or plugs?
Created on: 15 Feb 2020 08:17
Levingi
Levingi
15 Feb 2020 08:17
Hello everyone, I will be moving soon and want to set up my IKEA Billy shelves in my new rental apartment. Unfortunately, installing wall plugs or anchors is not allowed here or at least not an option, as the walls are very delicate and I want to avoid any damage.
So my question is: How can I safely install or secure Billy shelves in rental apartments without using wall plugs? Are there any alternatives that are stable and can securely hold the shelves without them falling over or causing damage to the walls?
I am especially thinking of options that take into account the typical walls found in rental apartments and perhaps consider the leaning shelf method or attaching with special adhesive brackets.
Tips, experiences, and specific suggestions are very welcome, even if they are a bit unconventional. Thanks in advance!
Danial
15 Feb 2020 08:45
Levingi schrieb:
How can I securely install or fix BILLY shelves in rental apartments without using wall plugs?
First, I notice as a drawback that many alternative fastening methods have limited durability. Especially with heavy shelves like BILLY, you need to weigh whether moving out or wall liability is more important than stability.
Have you checked whether so-called "residue-free" adhesive systems like strong mounting tapes or special adhesive hooks are truly sufficient for the weight of a fully loaded shelf?
Also: Is it possible to use the shelf as a freestanding piece of furniture and only secure it against tipping, instead of fully fixing the panel to the wall?
Roberta
15 Feb 2020 09:02
Levingi, take a look at so-called "leaning shelves." You don’t need to fix them to the wall. You can also set up BILLY without wall mounting if you leave some space and secure it against tipping, for example with furniture stoppers on the floor.
rigau
15 Feb 2020 09:26
Alternatively, you can try special adhesive hooks or hook-and-loop tape systems. These hold well and can be removed without leaving any residue. However, please do not support the entire load with the adhesive; use it only for stabilization.
Levingi
15 Feb 2020 10:04
Danial schrieb:
Is it possible to use the shelf as a freestanding piece of furniture and only secure it against tipping over?
Thanks, that’s a good point. I would actually like to set up the shelf very securely; it should stay reasonably stable in place—mainly because there are children in the household and also because I want to store books and folders in it.
I don’t necessarily want the shelf away from the wall, but rather leaning against it to save space. However, I would like to avoid drilling holes in the wall.
rigau schrieb:
Try special adhesive hooks or Velcro strip systems… not to bear the full weight, just for support.
How practical are these adhesive systems really with the weight of a fully loaded BILLY shelf? Has anyone had concrete experience with specific brands or products?
Are there maybe other physical solutions as well, e.g. pressure-mounted or tension systems, to secure the shelf?
Nigel
15 Feb 2020 10:39
Levingi, depending on the height of the shelf, you can use so-called tension rod brackets. They work like a telescopic rod from floor to ceiling with rubber pads. This way, the shelf stands firmly and does not require wall anchors or screws.
