ᐅ How can I install BILLY shelves in rental apartments without using wall anchors?
Created on: 24 Sep 2023 08:13
HauploHello everyone, I am currently facing the problem of installing my IKEA BILLY shelves in my rental apartment, but I want to avoid the usual drilling and wall plugs because, on the one hand, I don’t want to damage the walls, and on the other hand, my lease agreement clearly states that no structural alterations are allowed. Are there ways to mount the BILLY shelves securely and stably without using wall plugs or damaging the wall? I am open to all practical suggestions, whether special adhesive systems, specific constructions, or alternatives that still make the shelves stable. My main goal is to install the shelves so they won’t tip over and remain safe, without leaving marks on the wall. Thanks in advance for any tips and experiences!
Interesting question. Have you already checked if your landlord might agree, provided the mounting is reversible?
That obviously limits the options considerably. In principle, there are screw systems with adhesive plates or hook-and-loop fasteners, but their load capacity is usually limited. I would also be interested in how heavy the shelves are intended to be when loaded. Avoiding anchors tends to make the setup less secure, at least for relatively heavy shelves.
Hauplo schrieb:
I want to avoid the usual drilling and anchors because, on the one hand, I don’t want to damage the walls, and on the other hand, my rental agreement clearly states that no structural changes are allowed.
I share a similar view as kasan. For rental apartments, alternative fastening methods are often problematic when it comes to heavy furniture.
Is there no way to stabilize the shelves firmly on the floor without wall mounting? For example, using non-slip pads or tension rods between the top of the shelf and the ceiling?
Sometimes heavy-duty adhesive pads can at least provide a temporary solution, although their adhesion on textured plaster or painted walls can vary greatly.
Hauplo schrieb:
My main goal is to install the shelves so that they don’t tip over and stand securely without leaving marks on the wall.
I can understand how challenging it must be when you want to avoid damaging your apartment. I had a similar issue with a different shelf. What worked well for me was a combination of non-slip mats under the shelf boards and foam furniture protectors between the shelf and the wall. This provided a kind of "fixing" that isn’t a permanent attachment but prevents tipping during everyday use.
Maybe this can help you a bit as well? 🙂 If you have very heavy books or items in your Billy shelves, you should consider whether protecting the walls is more important than the stability of the shelf. Everyone has to weigh that for themselves.
The requirements for a fastening method without anchors (wall plugs) are technically challenging to implement because the stability of a BILLY shelf is primarily ensured by anchoring it to the wall. If the landlord strictly forbids drilling, the following alternatives are possible:
1. Telescopic tension rods between floor and ceiling: These are used in furniture construction to stabilize cabinets without drilling holes. The prerequisite is a full-height ceiling and sufficient compressive strength of the ceiling surface.
2. Heavy-duty adhesive tapes with high bonding strength: However, these do not permanently adhere to all surfaces and are only recommended for very light loads.
3. Clamping using furniture connectors or furniture rails that attach to the furniture and ceiling/floor – these require custom-made parts and precise planning.
In general, a combination of several of these measures is necessary if anchors are to be avoided.
