ᐅ How can I make my BILLY shelves childproof?
Created on: 1 Apr 2024 08:17
Hau_mo
Hau_mo
1 Apr 2024 08:17
Hello everyone, I’m looking for practical tips and recommendations on how to make my IKEA Billy shelves childproof. The shelves are in our living room, which is frequently used by our two toddlers. My main concerns are preventing the shelves from tipping over, stopping heavy items from being pulled down easily, and protecting the edges to prevent injuries. Are there proven methods for installing anti-tip devices, corner guards, or advice on optimal shelf organization to make the unit safer? Which products or DIY solutions are practical and reliable? Thanks for your informed suggestions!
andre3
1 Apr 2024 09:12
To secure BILLY shelves, I recommend always firmly anchoring them to the wall first. IKEA already provides suitable wall anchors that, when installed correctly, prevent tipping. Additionally, I suggest placing heavy items at the bottom to lower the center of gravity.
For child safety, transparent corner protectors made of soft plastic can also be used. These are easy to attach and prevent painful bumps.
It is also important to ensure that no easily removable items are within reach to avoid pulling and falling objects. Overall, a combination of wall anchoring, edge protection, and thoughtful placement of contents ensures reliable child safety.
te-min
1 Apr 2024 10:03
Wall mounting is mandatory. Corner protectors must be installed. Heavy items should be placed at the bottom. Children cannot reach anything dangerous.
LOGEMIN
1 Apr 2024 11:47
Here is a brief guide on how to make a BILLY shelf childproof:
1. Secure to the wall: Use the included mounting kits. Make sure to choose the correct wall plug depending on the wall type (e.g., cavity anchors for drywall).
2. Organize contents: Place heavy books and decorations on the lower shelves to keep the center of gravity low.
3. Corner protectors: There are self-adhesive, soft plastic corner guards. Pay attention to size and adhesive strength so children cannot remove them.
4. Prevent items from being pulled out: Use lockable boxes or baskets to secure small items.
5. Regular checks: Inspect the fixings again after a few weeks to ensure everything remains secure.
Common mistakes I often see: attaching the shelf only at the top instead of both top and bottom – this leaves the unit prone to tipping. Also, cheap corner protectors often do not adhere well and fall off.
ju_ren
1 Apr 2024 12:21
Furniture safety straps are a good idea. Use adhesive mounting kits instead of screws if you want to avoid damaging the wall.
Hau_mo
1 Apr 2024 14:33
andre3 schrieb:
It is also important that no easily removable objects are within reach
That is an important point. I am also considering whether to add dividers or boxes on the shelves to intentionally limit accessibility.
LOGEMIN schrieb:
A common mistake I often see: attaching only at the top of the shelf instead of both top and bottom
Thanks, I wasn’t aware of that. I thought attaching at the top would be enough, but fixing the shelf at the bottom as well makes it more stable. Do you know of any suitable mounting systems for BILLY shelves that are easy to install and not too visible?
