I am currently planning the layout for my storage area and intend to use IKEA Billy bookcases for this. Since I will be storing relatively heavy items there—mainly some technically heavy equipment and binders that weigh well over 20 kg (44 lbs) per shelf—I have the following question:
Which Billy bookcases are specifically designed for high load capacities, meaning which versions or modifications can support a lot of weight without losing stability?
If you have any experience with reinforcements or alternative shelves, I would also greatly appreciate hearing about that.
Thanks in advance!
Thanks in advance!
NUPIN schrieb:
A little tip: Place thin wooden battens underneath heavy floors as additional support – this greatly improves load-bearing capacity!This can work, but please be careful: A permanent load distribution should be done with screw-fixed reinforcements; otherwise, the material may warp or splinter over time.
Using wooden battens is a temporary solution and does not replace a proper structural design. I would recommend planning for individual reinforcements with metal profiles or brackets, especially for high loads.
In summary, I recommend the following for heavy loads:
- Use metal shelves
- Ensure secure wall attachment
- Do not reduce or remove the back panel
- For very heavy loads: consider additional reinforcements and possibly floor support
If the weight becomes very large, a professional shelving system may be more suitable than Billy.
- Use metal shelves
JAPLO schrieb:
If the weight becomes very high, a professional shelving system might be more suitable than Billy.Thank you for the honest assessment; that is very helpful. My load range is approximately 35-45 kg (77-99 lbs) per shelf, as it involves heavy equipment that is not extremely bulky.
I will probably go with the 80 cm (31.5 inches) Billy units with metal shelves and careful wall mounting, and I will follow the advice about using additional strips.
Thanks to everyone for the helpful information and tips!
