ᐅ Is it safe to use Billy shelves without securing them to the wall?
Created on: 17 May 2019 19:23
TAHEIN
Hello everyone, I hope someone here has experience with Billy bookcases from Ikea: My specific question is whether these shelves can be used safely without the recommended wall anchoring. I want to use a bookcase in a room where no wall plugs for anchoring are allowed, and I’m wondering if the shelf will still be stable enough to hold books and other items without tipping over or becoming a safety hazard. Are there any tips, reliable experiences, or perhaps alternative securing methods? Thanks in advance!
TAHEIN schrieb:
Is it possible to use these shelves safely without the recommended wall mounting?Hi! For those who can’t install the wall fixings: how about using two shelves arranged perpendicular to each other? This way, they are less likely to tip over and you even get more storage space. I’ve seen something like this before and found it really practical! :-)
DUKUSU schrieb:
take two shelves and arrange them crosswiseThat’s a good idea to create a small room divider or a more stable structure. However, it is important that the shelves are securely connected, for example with screws or brackets, and that the load is well distributed. Otherwise, while it may seem more stable, it does not replace a secured attachment to the wall. Especially bookcases often require vertical fixing, as they can become dangerous and tip over under load.
I think an important consideration regarding practical use is missing here: How will the shelf be loaded? Will heavy books or individual items that concentrate a lot of weight in one spot be stored at the top? This can significantly increase the risk of tipping. I recommend using the shelf without wall anchoring only if the heaviest loads are stored at the bottom and the shelf is placed in an area with little or no child access.
