ᐅ Which Billy bookcases are best suited for heavy books?
Created on: 15 Apr 2024 20:13
Dorian47
I am planning to fill several Billy bookcases from Ikea with relatively heavy books, including large-format reference works and hefty volumes weighing several kilograms (pounds) per shelf. My specific question is: which Billy bookcase models or versions are best suited for heavy books in terms of load capacity, stability, and durability?
I am interested both in the technical specifications of the shelves and their maximum load limits, as well as practical experience regarding stability when fully loaded. There are often reports of sagging shelves or instability under heavy loads with Billy bookcases.
It would also be helpful to know if there are special reinforcements, accessories, or tricks to increase the load-bearing capacity.
I look forward to precise tips and experiences, preferably differentiated by the common shelf widths and heights. Thanks in advance for your help!
nojaus
16 Apr 2024 19:17
I can understand the concern about heavy books very well. I had a Billy bookshelf myself that sagged quite a bit under the weight – not only does that look unattractive, but it also feels unstable.
In my case, reinforcements and securing the shelf to the wall helped significantly. It’s also important to store the heaviest books toward the bottom. Try to avoid concentrating weight on individual shelves and instead distribute it evenly.
Taking the time to do this properly is really worthwhile. Especially with books, since you don’t often rearrange them 😉 The durability of the shelf is crucial when it’s loaded heavily.
Dorian47
17 Apr 2024 08:59
Good morning,
thank you all for the detailed and thoughtful responses – they are very helpful. To summarize, I see the following key points:
- A depth of 40cm (16 inches) provides natural stability due to the shorter span but may not be optimal for storage space.
- A depth of 80cm (31 inches) is practical for larger books but should be reinforced with metal supports and wall mounting.
- A maximum of 5 shelves plus wall installation is recommended to prevent bending and tipping.
- Heavier books should be stored at the bottom with the load distributed evenly.
I will try combining the 80cm (31 inches) depth with additional metal beams and securing the shelf to the wall. If a combination of 40cm (16 inches) and 80cm (31 inches) proves useful, I will experiment with that as well.
If anyone has final advice or recommendations on suitable accessories, I would be happy to read them.
Lorukeo
17 Apr 2024 09:45
Dorian47 schrieb:
If anyone has any final tips or advice on suitable accessories
For reinforcing shelf boards, there are special metal profile accessories that can be screwed underneath the wooden boards – this significantly reduces sagging. Using thicker MDF shelves is also beneficial if replacement boards are being purchased.
Additionally, there are special metal shelf brackets that stabilize the side panels against deformation.
Don’t forget wall anchors; use fasteners suitable for the wall type, such as concrete or drywall anchors.
sifope
17 Apr 2024 10:16
Lorukeo schrieb:
There is special metal profile hardware for reinforcing shelves that can be screwed underneath the wooden boards
Very good tip.
Additionally, when choosing reinforcement hardware, it’s important to ensure that the supports not only reduce bending but also allow for even load distribution onto the side panels. Otherwise, the shelf may experience issues at the sides.
For wall mounting, an extra securing element at the top of the shelf can be useful, using metal straps or tension cables in addition to screws, especially if maximum stability is desired.
RENMA
17 Apr 2024 11:03
A brief addition:
A commonly underestimated method for stabilization is not only inserting the shelves but also securing them from underneath with screws or small brackets. This prevents the shelves from slipping and helps distribute the load more effectively.
A combination of adjustable shelves and fixed shelves (attached to the back panel) can also improve overall stability.
nojaus
17 Apr 2024 14:27
I really appreciate the technical discussions here. I can only confirm the tips about metal profiles and wall fixings.
Speaking of practical experience: If you store the heaviest books at the bottom and ideally use a grid-like arrangement inside, the shelf doesn’t feel so flimsy even under heavy load.
Good luck with your project!
